claws
More rust found inside drivers rear quarter so rear panels not finished today. Roof rust removal finished and apoxy sealer sprayed on. Rear end will get welded together next week.
| Tue Apr 24, 2018 10:18 am |
mate the speed you are going it will be ready for the next nationals ..........great job...cheers davo
| Tue Apr 24, 2018 9:01 pm |
KJB
Good to see progress on a serious resto.. Keep it up .
| Tue Apr 24, 2018 10:41 pm |
claws
More metal cleaning today and rust treatment, ready for sealer.
| Wed Apr 25, 2018 8:38 am |
CQGT
claws wrote: More metal cleaning today and rust treatment, ready for sealer. When you cleaned and treated the metal. How did you clean it and what is the product that you used.? The reason why I'm asking is that I'm at a similar stage of prep on my convertible body. I thought I was seeing "double" when you put your pic's up. Although. You have a roof and I haven't. Dave.
| Thu Apr 26, 2018 11:55 am |
claws
I will put up details with photos for you Sunday afternoon Dave.
| Thu Apr 26, 2018 11:18 pm |
KJB
Photos of your progress please Dave........ KB
| Fri Apr 27, 2018 12:31 am |
CQGT
Thanks claws. Sunday should be good. Will be away for a couple of days. Be back then.
KB. Have photos on USB. Time permitting I am endeavoring to see if I can start a new post on the work thus far and then continue. Nearly every panel has to be repaired due to it having been in a bingle at some time of its life. Rust in the usual places. Small creases and dents not beaten out. Just filled with bog. Getting there. Slow. At least all the suspension and brakes are ready.
| Fri Apr 27, 2018 11:42 pm |
claws
Cleaning metal started with combo of sanding discs, pads on sanders, grinders, wire wheels. Wire wheels good for getting into spot welds. Rust treated with an acid rust cleaner, (wearing long acid proof rubber gloves)applied then rubbed into areas turning black with sandpaper. Then wiped clean with a damp rag and dried immediately with dry rags. whole process repeated where rust still on metal. Some small bits of rust had to be removed with a die grinder. If any acid is left on metal it will turn white when it dries. It needs to be washed off and dried. Where parts were left for a few days without sealing i repeated acid treatment before sealing and then cleaned metal with acetone then was sprayed with the apoxy coating. I found that having as many different type and size sanding discs, pads, wire wheels as possible made the job easier. Most of these products have come from a business called Crash Supplies in Adelaide, don’t know if that is a an Australia wide chain. I did get a few bits from super cheap auto parts but they have only a pretty basic range compared to a proper auto body repair supplies.
| Sun Apr 29, 2018 8:10 am |
claws
Just cleaning interior floor this weekend. This area and boot will take a few weeks so wont put any more photos up till thats done. Got sills folded by my friend Graham who is the one who is in charge of this resto. They will be going on in a few weeks.
| Sun Apr 29, 2018 8:18 am |
1968GT
Hey Claws, what do you use the "Coopers" for , SANITY? You are doing a great job, will be very interesting to see the completed Resto!! Keep up the great work!!
| Mon Apr 30, 2018 4:33 am |
redback
Aaaah yes - wire wheels....... I call them "the wheels of death" Great work Claws and thanks for showing us how you are doing it all.
| Mon Apr 30, 2018 5:15 am |
CQGT
I've been using 3M rust dissolver before I puttied the damaged area. Similar process as to your product, but has to be cleaned and puttied or sealed within 20 minutes. I won't be using the 3M, I will be using a product called bondall Ranex. This is industrial strength rust buster. Similar process, but can leave it to completely dry. I'm going to give it a day. Re clean again and then prepsol or acetone it. Redback is right in calling those wire brushes "wheels of death". I wore a welding jacket when I used one of them. The wires broke off and speared into the jacket. Lucky I was also wearing glasses as one strand also speared into my left ear. The left pokes out further than my right. Halfa' wingnut you could say. I've gone back to using twist knot brushes. Thanks for the info. Will be following your 'Resto' with interest.
| Mon Apr 30, 2018 7:07 am |
GerryBellettGT
Great work and thanks for sharing,admire anyone who takes on a project like this,sure you get a great sense of achievement at different stages,good luck,I think the pr90 has the best dash,interior,grill,Gerry
| Thu May 03, 2018 9:48 am |
claws
Bit of an update, new sills ready to weld in, rear end started welding on, lots of metal cleaning, apoxy sealing, more updates as weather gets warmer.
| Fri Aug 17, 2018 9:09 am |
wow ……….………..so that's how its done …………………….wow ..you are the man …………...
| Sat Aug 18, 2018 11:13 pm |
claws
New sill welded and coated today, rear quarter coated. Will spend next 2 weeks finishing cleaning boot metal and interior floor metal before rest of rear end gets welded on.
| Mon Aug 20, 2018 8:35 am |
Love seeing the progress pics. Coming up very well indeed
| Thu Aug 23, 2018 6:09 am |
Ditto from me. Its great to see you doing the stuff I would be doing if time allowed. Ah well, retirement can't be too far away! Looking great! Cheers, Matt.
| Wed Aug 29, 2018 10:32 am |
claws
Rear end welding nearly finished, starting to look like something’s actually happening.
| Sun Sep 23, 2018 7:55 am |
Users browsing this forum: No registered users and 25 guests |
