Bolt on four pot brakes?
JT191
- bellett65
- Car(s): Isuzu DMax LSU, Isuzu MUX, 1979 117 Coupe.
Re: Bolt on four pot brakes?
I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. Tghe rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand.
JT191
For GT? It should be just two bolts holding the original caliper, right? If it were a conversion for a car which came with drums, that sounds like a problem. But would I have to add two more bolts if it only came with two just so that I could upgrade calipers?bellett65 wrote:I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. The rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand.![]()
- bellett65
As per piccy
As per piccy
- Attachments
- PICT2703.JPG (1.64 MiB) Viewed 37483 times
JT191
JT191
This is what I am thinking:
Sounds pretty good.
JT191
That's the smallest Wilwood vented disk is 10 1/4. That extra 1/2 inch diameter is probably going to cause a lot of clearance problems. With the 9.9 inch Nissan rotor, 13 inch steel wheels might fit. And they are $75 USD, almost twice as much as the Nissans. The Nissan rotor bolt pattern is more similar to the Bellett, so the hat or adapter will be more compact and simpler. Using this extremely large caliper on a small rotor causes clearance issues between the inside edge of the caliper and the hub.RobSA wrote:Sounds pretty good.
JT191
So, I have bad news.
have a look here:
http://www.bellett.net/forums/viewtopic.php?f=13&t=709
have a look here:
JT191
I'm new to this obscure corner of the already obscure Isuzu world, but not unable to operate a internet search engine. I've not found much of anything in the English speaking world as far as people selling performance or even replacement parts for Belletts. Who's selling brake kits or brake kit parts?PR91 wrote: honestly guys, this has all been done before, with the hard work of designing and fab'ing the caliper brackets done too, so why try to re-invent it??
Thanks Brett.
Thanks for the info on the different stub axles, can add that to the bank of Bellett knowledge
JT191
no probs rob.RobSA wrote: Did you need the booster because of the different pedal ratio, or just a function of the master cylinder to piston area?
exactly JT.JT191 wrote:I wasn't trying to be ignorant about it, but short of someone selling the exact piece needed, or a set of documented step-by-step instructions, just about everything we do for a Bellett or any Isuzu car is or is close to starting from scratch.
JT191
- Attachments
- DSC03164.JPG (147.81 KiB) Viewed 37089 times
JT191
