View unanswered posts | View active topics It is currently Wed May 27, 2026 12:34 pm
Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
Bellett found at local junkyard, a pair of foglights found
Hi Scott
I've already made my request ... I tried to keep it simple .... :)
In my association with Belletts (2 years) I have not seen one come up like this where it has been parted out (not in this country anyway) there parts cars else where in the world (but not many) please correct me if I'm wrong guys.
I would say get what's easy to get at... and how much time you want to spend doing this , as you know now the foglight lights had some value ....and you do not see gen-u-wine Bellett parts on ebay very much.
Valve cover
Carbs
switches and dash components
steering wheel
what else do you say Bellett.net members?!? cause I bettcha he's going there this weekend ..
good luck Scott
Regards
Mark
Fri Jun 25, 2010 7:52 pm
Car(s): 74 Alfa GTV, 65 Alfa Duetto, 67 Mercedes 250 S, 67 Mercedes 250 SL, Boring Prius, Boring VW Jetta
I just got back. Someone else already got the steering wheel previously. A person who arrived while I was there got the radio and various pieces of the dash/interior. Nice guy.
I got the following (and will provide pictures later):
Dual SU carb and intake manifold and air cleaners and associated cables
Tach/speedo instrument cluster that was in the trunk (not from this car)
Very good sunvisor
Center console with several switches and 5 round gauges in it, two of which were missing. (this was in the trunk also)
A center console with a cover that surrounds the emergency brake, probably of a different car
An extra chrome air cleaner cover in bad condition
Washer bag, might clean up, might not.
I thought about getting, but didn’t get:
Distributor with vacuum advance that was connected via a long tube to the carbs. (I did get the long tube)
Fuel filter mounted on inside of fender
Valve cover is still there but whatever holds it on is gone.
Should I get the distributor of fuel filter? There was a voltage regulator sitting in the trunk that I did not get. Also a spare tire and wheel.
Scott
Fri Jun 25, 2010 10:06 pm
Man thanks for the update! I better start checking ebay .... :lol:
Someone knew what they were after at least ...
Later
Mark
Fri Jun 25, 2010 10:47 pm
And no I wouldnt worry about the distributor and fuel filter .... (hope I'm telling you the right thing) ... :)
Mark
Fri Jun 25, 2010 10:55 pm
Here's a link to pictures:
http://photobucket.com/Bellett_Parts
That's what I got today, except Jeff got other stuff. Hi Jeff ! It was nice to meet you.
The sun visor and headlamp trim came from the car pictured in the California Junkyard Bellett thread. The other parts were in the trunk so I don't know what model/year they are. Oh, the carbs and intake came from the California Car too but I don't know if the dual carb setup is original to that are not...
thanks
Scott
Sat Jun 26, 2010 12:03 am
Hi Scott.
Twin SU and manifold and real yes and remote shift housing for gearbox a real yes as well.
Also any instruments and instrument clusters should be of some value if cheap enough.
Chris
Sun Jun 27, 2010 9:31 am
Except for the carbs, intake, and a headlight with chrome eyebrow, the Bellett parts that I have are on ebay now.
http://stores.ebay.com/Horse-and-Bear-E ... ec0Q2em322
thanks
Scott
Sun Jun 27, 2010 9:46 pm
