MitchMcD's 'Monster'
Re: MitchMcD's 'Monster'
gt orphan.... body deadener on a race car...?
that equals extra weight mate!
Fooolly dumped, Fooolly Sick !! That's a way cool Rat racer look you've come up with Mitch.
Getting rid of it at this stage takes time that could be spent doing other things a this stage. Temp solution black stripePR91 wrote:gt orphan.... body deadener on a race car...?
- 2ldohc
- Contact:
Maybe RobSA with Bella should be charging commission for this one
Go for it Mitch.
The more GTS's there are out there the better for all
At the moment, I that is unless I find another colour I like is for Bella to go pale yellow or gold with the current striping.
hey rob, mitch's dad did a few different colours to see what they looked like.
one was yellow....
i can post if u like.
and gt orphan.... deadener comes off a bellett pretty easily.... most just about falls off these days!
one was yellow....
ohh, and go the GTS mafia!
wonder where the 'GTS' monica came from tho....
Brett i had a play today now i am committed with the removal of deadener this is the easy weight to get out of it,and the fact that it half way up the doors it looked fugley. Now the 30kgs that hangs around the lower rib cage is another story
mate, seriously, i weighed the deadener out of my car (well, what i could weigh, as some 'disappeared' while sandblasting the whole body).
it weighed 18.5 kg.... no BS. i reckon it would have been over 20kg all up.
how much would u spend on chasing the HP needed to lug that around....?
- yellowperil
- Car(s): 1970 Bellett, 1968 Bellett, Triumph Stag, 1940 Traction Avant, T Ford 1938 Pontiac plus the usual modern stuff
Hi PR91
What's the best way of removing the sound deadener, it's one of my jobs coming up in January.
yp i got it off with a air sander using 80 grit sticky disc's $39 super cheap works well. i used 20 discs but it was 3 inches above the door crease. 70% of the door and suprise
little rust in front doors none in the rear ones, i left the bog alone in the rear quarters
i dont want to know.it looks as if new sills have been put on at some stage.
- yellowperil
Thanks Gt Sounds like one of those fun jobs!!
Brett,
Yes to posting a yellow GTS (warwick yellow, similar but lighter than yellowperils)
I'm saving my pennies for a new engine, whatever turns up
