Bellett Badges for Sale
- Early GT
- Contact:
I am now ready to release my small range of Bellett Badges to those in need. Although I am still experimenting in casting 1600GT badges in alloy, I have replicated the original diecast design and thickness with laminated plastic engraving plate on my Roland engraving machine (Now theres a Bellett just there) that I have used in conjunction with my Picture Framing business since 2007. My next one will be the long "Bellett" badge. Although I should be able to make the "1500" badge, I can't think of a way to create the thick chrome plated edges.They may have to have black edges. Check out the photos and prices below:
- Attachments
- 1600GT double sided keyring, $10 satin finish or $13 glass finish
- IMG_0650r.jpg (44.83 KiB) Viewed 12116 times
- 45mm dia. hub centre cap badges, Glass finish $48 set of 4
- IMG_0654r.jpg (48.73 KiB) Viewed 12116 times
- Later model GT Front Grille badge $25 Glass finish with threaded mounting posts
- IMG_0651r.jpg (41.3 KiB) Viewed 12116 times
- Set of 3 1600GT Badges $50 per set flat satin finish or $65 per set raised glass finish.
- IMG_0633r.jpg (37.16 KiB) Viewed 12116 times
JT191
Re: Bellett Badges for Sale
I like the look of the key chain. Now I need to either find a flat headed screwdriver with a hole drilled in the handle, or find a lock cylinder with a working key in it, and I will be able to use a key chain.
The glass finish is the old style baked on clear finish?
- pa_man
WOW, they look fantastic!!
- Farmer
They DO look fantastic!
Might have to raid the money box!
J.T., I take it you habe an ign lock cylinder? If so Dominion locks of Canada produced a key blank that is still available some places. You can take them to a locksmith & they skould be able to cut a key to match the lock. OR I could send you an old key & the smithy should be able to alter the tumblers to match the key.
Good luck.
Good luck.
- 1968GT
Hey Lewis,
Got the badges they look great, I have just returned form 2 weeks in NSW Country regions so I did not get them until today, Sunday.
Day off tomorrow, that will give me time to fit it up.
Thank you, I will fix the dollars this week when I get back to Sydney.
GREAT work, thank you.
DAVE m.
DAVE m.
