Dwell Angle is a clever way of measuring the points gap electrically.
and probably more accurate as gaping with a feeler gauge is very open to personal bias. some people like it to grab quite a bit while others use the it feels freee so must be right. i digress
to explain further..
a 4 cylinder car is therefore going to divide the total 360 degree travel of the rotor into 4 quarters.
each quarter is 90 degrees and the Dwell Angle meter is calibrated to measure the amount of open time compared to close time of the points. you have to choose if the car your working on is 4,6 or 8 cylinders and set the Meter to the correct setting.
most 4 cylinder cars have a Dwell Angel of 49 to 55 degrees. the car is turned over with the rotor, distributor cap and spark pugs removed and the Dwell Angle meter connected.
then the points gap is adjusted as the car is cranked over so the reading is within the 49-55 range. it is better to adjust closer to the 49 as the points will wear and the Angle will increase towards the 55 with time.
re-secure the two point adjusting screws and double check the angle has not changed as in locking down the points can influence this. so if angle moves to 55, adjust to 45 and when you lock down it should move to 49-50
then continue with the rest of your service, plugs, oil etc.
Remember to check your timing as points setup will effect it.
Your new points are set for 6-12 months of happy motoring
hope its not to technical
