1965 - Motor Trade Journal
- crownsixfour
- Car(s): 1968 Isuzu Bellett - SOLD to Kazmaxx, 1965 Isuzu Wasp, 1964 Toyota Crown, 1984 Toyota Sprinter AE86
My dad gave me this mag the other day doesn't have a article to go with the cover shot witch seems a bit odd but yeah seems like my scanner picked up the print cross hatching
- dave
- Contact:
Re: From the official organ
There's a setting that can fix that, but I've forgotten what it was! And because this computer is not currently connected to a scanner, it won't let me open the program so I can tell you what it is! When I next fire up the lappy, i'll check the setting and let you know. It would be good to look at the photo without incurring double-vision! Cheers for scanning it though! It's choice, bro.
- antus
- Site Admin
- Car(s): Gemini TX Coupe G200W Delco EFI, Gemini TX sedan (SR20DET, track car), Dato 1200 Ute, Subaru Blitzen Wagon (4th gen)
- Contact:
Scan it a higher res (600 dpi or above?), then scale it down on the PC to the correct size. Since the picture is made of black and white dots, scanning at to low resolution creates that funky effect. As dave says some scanners have a setting to fix it too, but i usually go hi res and scale.
- dave
- Contact:
I scan my brochures at:
High quality
300dpi
Descreen: Magazine (175lpi)
These are settings under MiraScan, but any other scanning tool should have something similar.
This makes the pictures pretty big and like Antus said, I normally reduce the size down (but I keep the full size one as well).
High quality
300dpi
- crownsixfour
it seems that when i re size it thats when the dots show up Meh im to high on cold and flue tablets will try later
- antus
- Site Admin
- Contact:
ahh, you need a better program then to do the resize. email me the hi-res version and i'll see what I can do it with then clean up the thread. thanks. [email protected]
- redback
- Contact:
Hey Guys,
This is the best I could do to fix the image. (PhotoChopped)
- Attachments
- This is not the original cover image!!
- scan0001 Option2.jpg (172.76 KiB) Viewed 19837 times
- dave
- Contact:
haHAHAHAH it's just not the same...
- redback
- Contact:
Gday Dave,
Yep - not the same at all. I was considering putting one of the members cars in there (even my own) - any takers?? post your photo up and I will slot it in!!
- crownsixfour
HA ha nice touch
- crownsixfour
message sentantus wrote: email me the hi-res version
