White drivers door to suit Bellett sedan
50 Bells Bellett
Post by 50 Bells Bellett »
Hi folks, just got back from holidays in Peru - didn't see any Belletts,but just about every other old car ever made.
Has anybody got a white colour ,straight drivers door to suit a Bellett sedan?
(I have a red one to swap if needed).Just the bare door shell is OK ,as I can swap the bits over.
I have a dinged up white one on it at the moment,but is a bit of an eyesore.
i will be at the Nats,so can pick up from there,
thanks,
Rod.
bembokabellettbloke
Re: White drivers door to suit Bellett sedan
Post by bembokabellettbloke »
Gary has some doors down here....Ill ask him
see you at the Nationals :mrgreen:
50 Bells Bellett
Thanks For that Gary,see you there soon!
Post by BULLITT »
mate if all else fails i have a couple here but no white ones ..just shells ..x woodburn see how you go with gary ..c heers davo
50 Bells Bellett
Thanks Davo,I will keep it in mind.The Teardrop is coming together.Got the seats all back in today & she starts and runs after 14 years laying idle :D
Still owe you some beers at Merimbula for those door trims :)
Post by PR91 »
remember to check what model Bellett the door is off before fitting tho...
even tho a sedan door will fit any sedan, they did change where the stainless trim was fitted. i can't remember which model was what, but i know the trim was moved from above the body line to below at some time.
we found this out years ago doing exactly as u are now...
Post by Farmer »
Brett, :shock: . Not sure when?? This should be in the quiz...........Change was with the tail lights. Teardrops have curved moulding above the crease, '66.5 hexagon lights and thereafter have pointed moulding below the crease.
One : Nill, mate! :P
Cheers, Matt. ;)
50 Bells Bellett
Thanks for the info guys - I got 2 white drivers doors on the weekend, 1 early , and 1 late and the stainless trim on the later one is about 15 mm lower than the other .
Thankfully I now know which one to fit to my Teardrop!
