Just had my carbies tuned and the car is running sweet, Out of curiosity I had Rufus run up on the dyno after the engine rebuild (plus 600km). Interesting that he made 98.4hp@4900rpm. Seperate test to 5200rpm 170kph showed a level off.
It only has a mild cam 1/8" bigger extractors and a bit of porting. Carbies are too small to achieve any more power. Not bad considering manufacturer's specs show 91horses at the flywheel 8- Good flat torque graph too, higher than manufacturers rating.
Rufus power!
- Early GT
- Contact:
Rufus power!
- Attachments
- Dyno test at Motacarb 27/9/12
- IMG_0606 (Small).JPG (45 KiB) Viewed 17619 times
- IMG_0608 (Small).JPG (25.67 KiB) Viewed 17619 times
PR95
Re: Rufus power!
Hi Lewis
Are you happy with the performance, did it make a lot of difference?
Geoff
Geoff
Re: Rufus power!
car looks good ..... all the work you have done on motor and only gaining 7 horses over standard not good
you would expect more
- Glenn
- Contact:
Re: Rufus power!
thats rear wheel HP, not quoted engine power. There are losses in the trans. so the rear wheel HP measured is pretty good I think.rod wrote:car looks good ..... all the work you have done on motor and only gaining 7 horses over standard not goodyou would expect more
Re: Rufus power!
Thats a big improvement the best guide would be research whp stock on 13 inch wheels/tyres
i think you would be supprised.
- Early GT
- Contact:
Re: Rufus power!
Yeah Geoff, considering a manual transmission car typically loses 16% of its flywheel
horsepower that means my engine is producing 133 net HP at the flywheel, whopping 45
more HP than standard G161. Greg, I am running std profile 13" wheels.
How did Mildred's 1st big drive go today?
I have been installing my new quarter window rubber seals today.... Bit tedious, and I discovered why the
LHS was siliconed shut... The top pivot spot weld is broken off.
if araldite doesn't work the window will have
to be siliconed shut again
Cheers, Lewis
Cheers, Lewis
Re: Rufus power!
We covered over 400km today 5 belletts 2 mazda rotories and a toyota. Mildred has been good,missy has a new engine and liz drove her today for the first time they are bonding quite well. OLyella had the charge light on but when we pulled up for fuel a wire was off, Okka and Trish,red bell has a temp sender issue. so far so good we head home tomorrow from gayndah
- Glenn
- Contact:
Re: Rufus power!
Lewis, as you will have seen, I have spare GT doors so if you need a top frame, let me know.Early GT wrote:Yeah Geoff, considering a manual transmission car typically loses 16% of its flywheel
LHS was siliconed shut... The top pivot spot weld is broken off.if araldite doesn't work the window will have
to be siliconed shut again![]()
Cheers, Lewis
Re: Rufus power!
It's only a rivet drill it out and replace it with a small stainless bolt and nut lock tight it. easey fix no 1 will pick it unless we tell em
