WASP PARTS
1968GT
WASP PARTS
Post by 1968GT »
Wanted is an alternator for a Wasp and steering wheel shroud?? ;)
Can anyone one assist please, urgent for a NSW fellow enthusiast!! ;)
pa_man
Re: WASP PARTS
Post by pa_man »
Steering wheel shroud is fine as I think its the same as a Bellett, well it is on mine.....thats no guarantee, if someone could confirm that would be great :ugeek:
Generator is another story, 65 Wasp should be a generator, NOW, there are a few alternators that seem to cross over as they are different to the latter Bellett, They have the screw type terminals and are marked A, F etc same as the generator.
As to if they use a different regulator hopefully another forum member may have a better idea :geek:
The early series Bellett should?? have the same generator and or the cross over alternator :)
Also if it is the generator you will need the back brackets for the alternator as well :geek:
I will check around and get back to you :D
Re: WASP PARTS
Post by PR91 »
you are spot on Josh.
shroud is early Bellett and Wasp's had a generator as standard.
is a generator or alternator that's needed Dave?
1968GT
Re: WASP PARTS
Post by 1968GT »
Checking I will get back to you, obviously the best price will be the cheapest, it is for one of our members. The car is still in pieces and is just about to be put back together.
How do we identify the correct regulator for either alternator or generator please?
pa_man
Re: WASP PARTS
Post by pa_man »
If you can get and post a pic of the regulator and possibly the bracket on the engine if its still there, as the bracket for the generator is longer, we can hopefully work it out!
