If anyone has good condition late model clip on type window winders please let me know??
BOTH my late model window winder knobs have come loose on the return trip from the Nationals.
Otherwise the GT behaved itself perfectly, down and back!!
Window winders.
1968GT
Window winders.
pa_man
Re: Window winders.
Will have a look, but think I can help
1968GT
Re: Window winders.
Thank you Josh,
I also require a seal or part number for a seal for the diff, pinion seal??
I have a very small mist around the front of the diff, which was there before Merimbula.
I would appreciate any assistance, the seal part number or equivalent part or number would be fine!
Re: Window winders.
if you get desperate hq holden window winders fit brand new ones available.
the seal size is 35mm id 65mm od and 10mm thick or 35x65x10 tc
1968GT
Re: Window winders.
Thank you Greg.
That window winder info is great.
I only have a slight whisper of a leak from the oil seal, I figure if I get one that fits, I can fix on a free weekend.
Thank you to you, Lizzy Geoff and Christine, for everything over the Nationals WEEKEND, what a great weekend, also for your prompt entry into CARnivale'.
