rear wheel cylinders
Post by BULLITT »
after much cussing and scunn knuckles I got the frozen wheel cylinders off wow this is all a learning for me now I will get them rekitted at gerrys mates place ..better brakes southport where he is at the moment doing the shoes and elfin drums will get them done then jack the front up pull the discs ,,callipers etc and do the costing whether its Isuzu or something else we shall see ...one at a time thank you for your advice ..matt,glenn,gerry and lewis ..the forum is a great help .....
Re: rear wheel cylinders
Post by BULLITT »
sorry and you too brett for your thoughts on the kit time ...and dave nq
Retroasted
Post by Retroasted »
Always great service at that place. And he knows his stuff
Post by BULLITT »
yes luke he is a wealth of knowledge he talked about parts of the brakes id never heard of I just nodded my head ..I think he was on to me ''bloody muso'' hes thinking have a gtreat w/e im going to see 90 get the water pressure thingy on to the underneath I have band aids and towels and togs cheers davo
CQGT
Post by CQGT »
Just had a master cylinder and 2 rear wheel cylinders done up. Sleeved and re-kitted.
He had to soak the rear cylinders for 3 days as the pistons had locked up. Not surprised really.
I put it down to the brake fluid absorbing the H20 from out of the atmosphere and the length of
time since manufacture. Once a bottle of brake fluid is opened and some of the contents are used,
don't put it in the boot as a JIC. (Just In Case). Buy a new bottle as a spare. Dispose the used 1
carefully. Nissan and Hyundai schedule the brake fluid to be changed at least every 2 years or 40000
or 35000 respectivly.
Post by Farmer »
Yep Dave, I change the Sube brake fluid every 100 000 wheater it needs it or not!
Probably due to flush Doris' through again. Gets rid of that moistue soaked stuff which can ruin yout cylinders.
Post by BULLITT »
well rear brakes are done , cylinders resleeved,rebonded brakes and the drums skimmed and sandblasted handbrakes etc all working great ..now to the front all the parts are there now getting checked out ......bit by bit cheers davo
