HEATER CONTROL TAP
HEATER CONTROL TAP
Hi guys got to put on the gemini fan (plastic better than steel so they say ) and the heater tap is r/s anyone know where and how I get these I can put it back on but as we all know bellett do like a nice flowing cool system anyone help a old muso .. I have some windscreen wiper arms to swap or inside lights good covers ......cheers davo
- Yahoo Messenger: [email protected]
Re: HEATER CONTROL TAP
Heater tap???
yes It comes out the water pump
Mine has the tap built into the heater itself, on right hand side. Can't recall now but early cars had tap on the engine i think.BULLITT wrote:yes It comes out the water pump
mine appears to have 2 the engine one I have unfroze thanks to joshs advice soak overnight in rp7 the other on the heater itself is hard frozen perhaps at one time they have bypassed the inside one and used the one at the motor for controlling in the winter mths ?? ...option is to have the radiator guys put on a new tap at the interior heater and have the motor free flow ??
You can frre up thr internal tap. Its a bit tough to get out but once cleaned up and a new o ring fitted. Will be fine.BULLITT wrote:mine appears to have 2 the engine one I have unfroze thanks to joshs advice soak overnight in rp7 the other on the heater itself is hard frozen perhaps at one time they have bypassed the inside one and used the one at the motor for controlling in the winter mths ?? ...option is to have the radiator guys put on a new tap at the interior heater and have the motor free flow ??
Just to add, if you haven't tried to remove the tap from the water pump, then don't. I broke the housing of my pump trying when I was 17. It had welded itself in place.
As long as it is open, you can fix or replace the inside one. My Florian has an inline one on the inner guard. Ok, you have to stop and open the bonnet, but it takes seconds.
much to the dismay and shock of james in Tassie I told him I got the old tap out of the water pump he was astounded it didn't crack the water pump as did matt ...I was lucky I guess or dumb ..maybe the second the radiators have both been cleaned the heater inside has had the tap removed and I will work the heater from the old tap which after some advice from josh (thank you) it now works great again cheers and thanks everybody ..davo
