Technical question
claws
- Car(s): PR90, PR91, Teardrop Bellett Sedan, 1979 Pontiac Trans Am Firebird, 1975 HJ Belmont Ute,Yamaha YB100
Technical question
Is this gt spring likely to nearly kill me if I unhook the end and how would I get it back on.
Re: Technical question
Hi Claws
I guess the answer to your first question is no
Is that the reclining seat spring ?
Springs are a pain in the arse but they will go back with patience
I cant tell you the answer to the second part of your question but I am sure someone on here can
Any more pictures of your wonderful rebuild?
Cheers Flying
Cheers Flying
- Farmer
Now theres something I've never tried. It does look pretty tight and would probably be pretty hard to get back in place.
I reckon I'd hold the whole thing securely in a vice or super jaws, then use long nose vice grips to check the tension. If its too strong, maybe take it to an engineering shop.
Sorry I'm not more help.
