Wanted, 2 row crank pulley to suit a G180 SOHC engine.
I'm toying with the idea of fitting air con to my Sport. I know it's been done before as an option perhaps so the pulleys must exist.
Maybe someone has a SOHC engine kicking around with the 2 row pulley?
Air Con
toomanybelletts
- Car(s): see user name
Re: Air Con
Ii have one thar may do . Let me know by fone .
Re: Air Con
Many thanks Craig.toomanybelletts wrote:Ii have one thar may do . Let me know by fone .
Re: Air Con
Hello Glenn, I checked the Sport motor, it only has a single row pulley, so I hope Craig has one for you.
Re: Air Con
Craig has an old motor and the pulley was just right, 2 rows.Farmer wrote:Hello Glenn, I checked the Sport motor, it only has a single row pulley, so I hope Craig has one for you.
Re: Air Con
Excellent!
Re: Air Con
I'm still working out how to do it all...... by s/h bits from a wreckers to adapt to the Bellett of buy one of the 'universal' kits that cost about $1500Farmer wrote:Excellent!
Re: Air Con
At least universal is new. Older units would need retrofitting and seals.
It's a universal one in Gary's blue sedan, and it works great.
Re: Air Con
Good point there Matt.Farmer wrote:At least universal is new. Older units would need retrofitting and seals.
Long time since i saw A/C in a Bellett and only in pictures. I assume under the glovebox. The kits i have looked at on line are usually a pretty tight fit in a Bellett by their measurements.
toomanybelletts
Re: Air Con
Hello Glenn , I'm glad it fitted .
Re: Air Con
Glenn, in Gary's it's fitted in place of the original heater facia, so as not to take up knee room. But in the sport with its proper heater console, you probably wouldn't want to do that. I wonder if it could be mounted on top of the transmission tunnel?
I'm not sure how George set up the heater though. I was there last week, but was more interested in going for a run than examining the details. But that would be fun too!
I could ask Gary to take some photos.
Re: Air Con
Hi Matt, I looked at the space behind the Sport heater controls, and just no space. You can get these kits as heater/cooler though which would mean removing the existing heater and maybe it would fit in there but that would be a last resort. From what I can see these kits only recirculate the air. Not ideal.Farmer wrote:Glenn, in Gary's it's fitted in place of the original heater facia, so as not to take up knee room. But in the sport with its proper heater console, you probably wouldn't want to do that. I wonder if it could be mounted on top of the transmission tunnel?
They 'might' fit in the parcel shelf area but really would have to have one to try before ideally.
Here's a link to kits https://autoaer.com.au/collections/air- ... oning-kits
ANOTHER LINK
https://www.tcrcarponents.com.au/car-ai ... ford-chev/
