Wanted, info on G180SS valve clearances
Posted: Fri Feb 25, 2022 4:58 am
by Glenn
Hi All
Myself and another G180SS engine owner are looking for clearance specs for inlet and exhaust valves.
Any other similar info would also be nice.
I have the PR60 Sport owners manual and lot's of specs in there but all in Japanese and so far can't decipher what the clearances are, if they are indeed given.
Mark, in UK I assume must know, and some of the Euro group too.
Re: Wanted, info on G180SS valve clearances
Posted: Tue Mar 01, 2022 8:48 pm
by Dick
Hi Glenn,
The inlet clearance on the SOHC 1600 and 1800 is:
In - cold is 0.101 mm
Out - cold is 0.151 mm
There s no rattle, but a kind of rhythm is always there.
Gr Dick
Posted: Thu Mar 03, 2022 1:17 am
by Glenn
Dick wrote:Hi Glenn,
Gr Dick
Many thanks Dick
Posted: Sat Mar 19, 2022 2:48 am
by Glenn
I scanned a section of my PR60 owners handbook with a Japanese to English translate Ap.
While I had no doubt of Dicks info, it was neat to try the scan and see what it did. (google translate Ap on my phone)
Before and after .............
Posted: Sun Mar 20, 2022 4:03 pm
by Pombellett
The clearances are tight aren't they?....don't forget if you're running anything other than a standard cam you might want to open them up a bit.
After two munched cams and much head scratching we opted for 0.23 ex and 0.18 in.....and it seems to be working pretty well.
Posted: Tue Mar 22, 2022 6:22 am
by Glenn
Pombellett wrote:The clearances are tight aren't they?....don't forget if you're running anything other than a standard cam you might want to open them up a bit.
Hi Mark, I'm no mechanic and to be honest, have never adjusted clearances my self. But the numbers above did seem 'tight'. Sorry to hear 2 cams paid the price.
