This neat little brochure for the c1967 Bellett sedan is presented in a slightly-wider-than-postcard format and opens horizontally. There is also a bigger, full size version of the same brochure!
On the front cover we have the handsome Bellett cruising across the causeway....
...while the second page features two happy Japanese families parked with their Roman-red Bellett and white Bellett down by the water. Check out the scuba gear!
Onto the Engrish, with the proud announcement that the car has a 19.6 second quarter-mile time! I'd keep that one to myself normally.
Interesting to note the Bellett features 'living-room comfort', 'easy-to-scan' instruments and that all controls are positioned for easy accessibility to the driver. Then why are the wipers on the PASSENGER side of the car (on RHD at least)?!?!?!
Note the use of a nearly-midget-sized Japanese girl to show off the rear legroom. Belletts still using standard runners on the front seats have plenty of rear legroom as the front seats don't go back far enough! Check out the plastic on the door trims! Mint!
This panel is the one you see when you first open the brochure and features info on the engine. Pretty light on the Engrish on this page, but still good!
Finally we have the Bellett's specifications in metric and imperial measures like all good Bellett brochures. Plus a big area for your local dealer to put his stamp.
1967 Isuzu Bellett sedan small brochure - English language
dave
