interchangable head
Posted: Thu Apr 15, 2010 8:29 am
by gt orphanage
Can anybody comfirm if a head off a 5 bearing engine will fit a 3 bearing block?
Re: interchangable head
Posted: Fri Apr 16, 2010 12:17 am
by PR20 Auto
I do know that a three bearing head will fit a five bearing block if you drill out the bolt holes (from 10mm to 12mm). I can't see why the opposite can't be true if you re-tap the block (from 10mm to 12mm).
(Some-one on this forum owns the auto sedan that has a three bearing head on it. I helped to do it. It also has one of my rear windows with it to replace the broken one it had on it when they bought it.)
Posted: Fri Apr 16, 2010 12:21 am
by PR20 Auto
I just thought. You could also sleeve the bolt holes, but that would leave you with the skinny little 10mm three bearing head bolts.
Posted: Sat Apr 17, 2010 2:46 am
by gt orphanage
thank you that helps me make the decesion at hand.
