rear wheel cylinder problem. Help !
Hi folks,
jeff in Scotland here. Got weeping seals in my rear wheel cylinders. Bores look good, seals look knakkered. Anybody know a replacement seal off the shelf from another manufacturer. Want to try to avoid resleeving for the time being.
Many thanks, jeff
Many thanks, jeff
Re: rear wheel cylinder problem. Help !
Jeff send Dick a p.m would be your 1st port of call. there is a repco part number in the parts section on the forum i can see if they are still around or i get a company to do mine they get them from somewhere
shoot me a p.m if dick can't help.
Greg
Greg
- oz_toffa
Front seal P6121
Rear seal P5151
Cyclinder Kit Master K7308X
below is pic of rear seal
Rear seal P5151
- Attachments
- IMG-20120424-00008.jpg (93.33 KiB) Viewed 39536 times
- IMG-20120424-00007.jpg (113.09 KiB) Viewed 39536 times
hi there oz toffa what do they cost for the seals ? mines arnt leaking but good to have spares ?ready avail? ...still waiting for the nz blinker stork ...waiting waiting ...it will come cheers davo
- oz_toffa
less than $10 dollars each. older receipts say $5.15 but from memory last few i bought were still reasonable..
and still easily available. most PBR seem to have stock on shelves
not so sure of O/S though
could always drop a few in the post, Jeff.
- 65bellett
- Car(s): 65 and 66 sedan
Hi Jeff I think but I can't be 100% that you can use Morris Oxford seals or you may be able to use the entire wheel cylinder. As you are in the U.K these might be some thing you can get your hands on.
many thanks for all your help guys. Will Dick in Holland a go, or try the morris oxford route !
Thanks, Jeff
Thanks, Jeff
- 65bellett
I have just spoken to tomanybelletts (craig) and he uses Morris 1000 rear wheel cylinders on one of his cars. You have to change the nut as the bellett brake nut won't fit.
If you do go down the path of using another part I would love to know the part numbers and costing as I might grab a couple for spares
mr 65 bellet,
So delighted to have this site with fellow bellet owners, as these cars ain't falling out of the trees here in Scotland. Theres only 1. mine.
Have tried to use MG magnette rear wheel cylinders which look pretty much identical to the morris 1000 ones as recommended by dick in Holland. Could not get rid of the air from the system as these cylinders don't have any bleed nipples. Be interested to hear how craig overcame this.
Also googled pbr trying to find part number p5151 but nothing seems to come up - dont understand why as i can see p5151 printed on the packet of the photo that oz toffa posted.
Any suggestions?
Thanks guys
Any suggestions?
Thanks guys
- oz_toffa
Jeff
PBR do a local numbering system here in AU so unless someone else is selling NOS or stock online, it probably wont show up.
I was quite serious about putting a few sets of front and real seals into postage and send over. and also Master cyclinder kit if you want it.
just let me know. direct work email is [email protected]
good gesture oz toffa ...keep em all up and going cheers davo
- 65bellett
If you already have the wheel cylinders and they fit you are half way there. If you use this part
http://www.ebay.com.au/itm/Rear-Brake-B ... 4158wt_812
you should be able to bleed them up and get out there Belletting.
Mr Oz toffa, think I'l take you up on your offer ! Think its better to keep parts as original as possible so I'm gonna run with re sealing old cylinders and keep the brake bleedy thing in reserve, but thank you for the info 65 bellett - if either of you guys (or anyone on the forum needs stuff sourced in Britain give me a shout).
Thanks all, Jeff
Thanks all, Jeff
hey jeff what bout a shot of your ''wee beastie'' we all love to see where each other are up to on their cars ..good luck with the brakes we need em especially in reverse .... cheers davo
- oz_toffa
2nd that. love seeing photos of Belletts
update on part numbers. PBR have changed some things.
P6121 Front Seal $5.00 each
P8348 Rear Seal $4.20 each
cheaper than when i last bought some??
on shelves and seems like plenty of stock.
one set on the way to Jeff as soon as i have his address. Probably send in a CD case.
- Glenn
- Contact:
where did you buy the parts from?
My local Repco branch has no record of these numbers.
- oz_toffa
local Power Brakes branch in SA
website is powerbrakes.com.au
not sure if SA only or interstate
- Glenn
- Contact:
appears to be SA only
tried my local Bursons and no stock
- 65bellett
Glenn I have no doubt BGT would have them or would have no problems getting hold of them and they are over your side of town now.
- Glenn
- Contact:
I don't need them as no car but thought if they were available locally might stock up anyway
I found some but a bit of a drive away
didn't think of BGT though. I have dealt with them many times in the past. They did the clutch in my old GT too..
* BGT have been in Dandenong for as long as I can remember.
