rear wheel cylinder problem. Help !
jeffgair
Post by jeffgair »
Hi folks,
jeff in Scotland here. Got weeping seals in my rear wheel cylinders. Bores look good, seals look knakkered. Anybody know a replacement seal off the shelf from another manufacturer. Want to try to avoid resleeving for the time being.
Many thanks, jeff
Re: rear wheel cylinder problem. Help !
Post by gt orphanage »
Jeff send Dick a p.m would be your 1st port of call. there is a repco part number in the parts section on the forum i can see if they are still around or i get a company to do mine they get them from somewhere :?: shoot me a p.m if dick can't help.
Greg
oz_toffa
Post by oz_toffa »
Front seal P6121
Rear seal P5151
Cyclinder Kit Master K7308X
below is pic of rear seal
IMG-20120424-00007.jpg[/attachment [attachment=0]IMG-20120424-00008.jpg
Post by BULLITT »
hi there oz toffa what do they cost for the seals ? mines arnt leaking but good to have spares ?ready avail? ...still waiting for the nz blinker stork ...waiting waiting ...it will come cheers davo
oz_toffa
Post by oz_toffa »
less than $10 dollars each. older receipts say $5.15 but from memory last few i bought were still reasonable..
and still easily available. most PBR seem to have stock on shelves
not so sure of O/S though
could always drop a few in the post, Jeff.
65bellett
Car(s): 65 and 66 sedan
Post by 65bellett »
Hi Jeff I think but I can't be 100% that you can use Morris Oxford seals or you may be able to use the entire wheel cylinder. As you are in the U.K these might be some thing you can get your hands on.
jeffgair
Post by jeffgair »
many thanks for all your help guys. Will Dick in Holland a go, or try the morris oxford route !
Thanks, Jeff
65bellett
Post by 65bellett »
I have just spoken to tomanybelletts (craig) and he uses Morris 1000 rear wheel cylinders on one of his cars. You have to change the nut as the bellett brake nut won't fit.
If you do go down the path of using another part I would love to know the part numbers and costing as I might grab a couple for spares :D
jeffgair
Post by jeffgair »
mr 65 bellet,
So delighted to have this site with fellow bellet owners, as these cars ain't falling out of the trees here in Scotland. Theres only 1. mine.
Have tried to use MG magnette rear wheel cylinders which look pretty much identical to the morris 1000 ones as recommended by dick in Holland. Could not get rid of the air from the system as these cylinders don't have any bleed nipples. Be interested to hear how craig overcame this.
Also googled pbr trying to find part number p5151 but nothing seems to come up - dont understand why as i can see p5151 printed on the packet of the photo that oz toffa posted.
Any suggestions?
Thanks guys
oz_toffa
Post by oz_toffa »
Jeff
PBR do a local numbering system here in AU so unless someone else is selling NOS or stock online, it probably wont show up.
I was quite serious about putting a few sets of front and real seals into postage and send over. and also Master cyclinder kit if you want it.
just let me know. direct work email is [email protected]
Post by BULLITT »
good gesture oz toffa ...keep em all up and going cheers davo
65bellett
Post by 65bellett »
If you already have the wheel cylinders and they fit you are half way there. If you use this part
http://www.ebay.com.au/itm/Rear-Brake-B ... 4158wt_812
you should be able to bleed them up and get out there Belletting.
jeffgair
Post by jeffgair »
Mr Oz toffa, think I'l take you up on your offer ! Think its better to keep parts as original as possible so I'm gonna run with re sealing old cylinders and keep the brake bleedy thing in reserve, but thank you for the info 65 bellett - if either of you guys (or anyone on the forum needs stuff sourced in Britain give me a shout).
Thanks all, Jeff
Post by BULLITT »
hey jeff what bout a shot of your ''wee beastie'' we all love to see where each other are up to on their cars ..good luck with the brakes we need em especially in reverse .... cheers davo
oz_toffa
Post by oz_toffa »
2nd that. love seeing photos of Belletts
update on part numbers. PBR have changed some things.
P6121 Front Seal $5.00 each
P8348 Rear Seal $4.20 each
cheaper than when i last bought some??
on shelves and seems like plenty of stock.
one set on the way to Jeff as soon as i have his address. Probably send in a CD case.
where did you buy the parts from?
My local Repco branch has no record of these numbers.
oz_toffa
Post by oz_toffa »
local Power Brakes branch in SA
website is powerbrakes.com.au
not sure if SA only or interstate
appears to be SA only
tried my local Bursons and no stock
65bellett
Post by 65bellett »
Glenn I have no doubt BGT would have them or would have no problems getting hold of them and they are over your side of town now.
I don't need them as no car but thought if they were available locally might stock up anyway
I found some but a bit of a drive away
didn't think of BGT though. I have dealt with them many times in the past. They did the clutch in my old GT too..
* BGT have been in Dandenong for as long as I can remember.
