[ 11 posts ] |
1968GT
Hi there can anyone provide me with the part number or good alternative for the brake light switch please? I need to replace mine and I want to stay original, so I do not wish to change the set up. My current switch has died and I will need it fixed before July/
Please poist here or PM me?? Dave M (1968gt).
| Sun Jun 17, 2012 7:01 am |
Dave i use hella part no 4566 no mods needed
| Sun Jun 17, 2012 7:15 am |
1968GT
Thank you, that is exactly what I wanted, a part number, I will try again. Did you havr any trouble removing the faulty part? I am having difficulty getting faulty switch from the little 4 way brass block? Dave M.
| Wed Jun 27, 2012 7:05 am |
They just unscrew maybe vise grips just support the t piece or you may kink a line if it turns.
| Wed Jun 27, 2012 7:10 am |
1968GT
In think it might be a case of cutting it off and using an easy out drill bit, it is very tight?? I have soaked the spare I have in WD40, still wont budge, I will keep trying. Thanks again.
| Wed Jun 27, 2012 7:25 am |
1968GT
Picking up the brake light switch in the morning, a spare also, just in case of another failure, as this one is the second time! Thank you for your assistance, thank you to Bellett.net also!!! DM.
| Thu Jun 28, 2012 11:31 am |
Hi Dave, The switch generally seems to weld itself into the brass union. I usually swap the assembly. If you need a union with switch removed I have one I can mail you.
Cheers mate, Matt.
| Fri Jun 29, 2012 11:39 am |
1968GT
Matt, You are a great Mate, thank you. I did find a union however and I hagve a new switch installed, all I have to do is now fit it and then bleed the brakes, a pain in the back side job!! Thank you again. Dave M.
| Mon Jul 02, 2012 4:25 am |
No worries mate, glad you're sorted. Surely Marg will push the pedal for you?? I know what you mean, Brake fluid! Stinky stuff. And it doesn't seem to matter what I do, it always gets all up my arms!  I've just re-kitted the wheel cylinders on 'Julius' (Roman Red). Glad thats done. Cheers, Matt.
| Thu Jul 05, 2012 1:24 pm |
1968GT
Hey Matt, I now have a leak at the union under the brake light switch, I will see how I go trying to fix it, if it ends up cracked or thread stripped somehow I might take you up on the union offer if you still have the spare please? I have tried to tighten it up a tiny bit more to see if the leak stops, same deal you get a bit worried about stripping the thread doing it up too tight, then when it is not tight enough the damed thing leaks, catch 22 eh!!!  Dave M.
| Sun Aug 05, 2012 5:13 am |
Yeah, its a fine line. What if I send it anyway, then if theres a crack or something, you'll have it in your hand. Can't remember your address though, you might have to send it to me. Cheers, Matt.
| Sun Aug 05, 2012 12:22 pm |
[ 11 posts ] |
Users browsing this forum: No registered users and 21 guests |
