Brake light switch~~
1968GT
Post by 1968GT »
Hi there can anyone provide me with the part number or good alternative for the brake light switch please?
I need to replace mine and I want to stay original, so I do not wish to change the set up.
My current switch has died and I will need it fixed before July/
Please poist here or PM me??
Dave M (1968gt).
Re: Brake light switch~~
Post by gt orphanage »
Dave i use hella part no 4566 no mods needed ;)
1968GT
Post by 1968GT »
Thank you, that is exactly what I wanted, a part number, I will try again.
Did you havr any trouble removing the faulty part? I am having difficulty getting faulty switch from the little 4 way brass block?
They just unscrew maybe vise grips just support the t piece or you may kink a line if it turns.
1968GT
Post by 1968GT »
In think it might be a case of cutting it off and using an easy out drill bit, it is very tight??
I have soaked the spare I have in WD40, still wont budge, I will keep trying.
Thanks again.
1968GT
Post by 1968GT »
Picking up the brake light switch in the morning, a spare also, just in case of another failure, as this one is the second time!
Thank you for your assistance, thank you to Bellett.net also!!!
DM.
Post by Farmer »
Hi Dave,
The switch generally seems to weld itself into the brass union. I usually swap the assembly.
If you need a union with switch removed I have one I can mail you.
Cheers mate,
1968GT
Post by 1968GT »
Matt,
You are a great Mate, thank you. I did find a union however and I hagve a new switch installed, all I have to do is now fit it and then bleed the brakes, a pain in the back side job!!
Thank you again.
Post by Farmer »
No worries mate, glad you're sorted. Surely Marg will push the pedal for you??
I know what you mean, Brake fluid! Stinky stuff. And it doesn't seem to matter what I do, it always gets all up my arms! :( I've just re-kitted the wheel cylinders on 'Julius' (Roman Red). Glad thats done.
1968GT
Post by 1968GT »
Hey Matt,
I now have a leak at the union under the brake light switch, I will see how I go trying to fix it, if it ends up cracked or thread stripped somehow I might take you up on the union offer if you still have the spare please? ;)
I have tried to tighten it up a tiny bit more to see if the leak stops, same deal you get a bit worried about stripping the thread doing it up too tight, then when it is not tight enough the damed thing leaks, catch 22 eh!!! :evil:
Post by Farmer »
Yeah, its a fine line. :?
What if I send it anyway, then if theres a crack or something, you'll have it in your hand.
Can't remember your address though, you might have to send it to me.
