degruch
Hi all, I've requested most of these before, but they're spread amongst various posts - I'm looking for the following PR91 GT parts:
> GT speedo in MPH > Rear parcel shelf speaker bezel (preferably 2) > GT radio and bezel > GT fog lamps and brackets > GT owners manual
Non-GT specific:
> Rust free rear beaver panel
If anyone has these parts for sale, please let me know.
Cheers, Duane
| Tue May 06, 2014 1:18 pm |
degruch wrote: Hi all, I've requested most of these before, but they're spread amongst various posts - I'm looking for the following PR91 GT parts:
Non-GT specific:
Cheers, Duane I have one GT fog lamp with cracked lense. 2 genuine brackets that could be restored although a little bent and chrome is stuffed. You 'might' be able to cut out the speaker bezels from a couple of sedan parcel trays if all else fails and graft them into a new GT type shelf. ? Use Vynal spray to complete the job in desired colour.
| Tue May 06, 2014 11:15 pm |
degruch
Thanks Glenn! I may be interested in what you have...just chasing another lead atm.
The speaker bezels are the same on all Bellett models? If so, yes...sedan, GT, any bezels will do, as long as they are black.
| Mon May 12, 2014 11:46 am |
degruch wrote: Thanks Glenn! I may be interested in what you have...just chasing another lead atm.
The speaker bezels are the same on all Bellett models? If so, yes...sedan, GT, any bezels will do, as long as they are black. I don't know if they are the same. But does not matter if you are making a whole new board and have 2 sedan ones for example to patch in. Most people won't even notice if they are. Colour can be changed anyway using spray paint. Especially if common colour, black etc
| Mon May 12, 2014 11:23 pm |
PR95
Don't know that sedans had a speaker grill, from memory they had a deep well and were slotted where the speaker was attached to a plate under the parcel tray.
| Tue May 13, 2014 12:58 am |
PR95 wrote: Don't know that sedans had a speaker grill, from memory they had a deep well and were slotted where the speaker was attached to a plate under the parcel tray.  yes, its moulded into the tray but could be removed with a jig saw very carefully and slotted into a new GT shelf i would think. Would need some careful work but would end up pretty nice i think.
| Tue May 13, 2014 2:08 am |
glenn why don't you help him out and make one for him cheers davo
| Tue May 13, 2014 6:25 am |
BULLITT wrote: glenn why don't you help him out and make one for him cheers davo I don't have 2 sedan shelves ! what i would probably do....... get two sedan shelves carefully cut around the grilles with a jig saw, leaving a little extra material to remove them from both shelves. Carefully pare back with sharp knife around the outside to make them 'nice' insert them into a new blank shelf for the GT. Possibly make shelf from 3mm MDF, covered in vynal, stitched to look like a GT one. Maybe wrap the vynal though the holes. Then glue in vents of course. Ensure the holes cut are very close fit before doing this to make sure the end result looks good. Paint with Vynal spray
| Tue May 13, 2014 7:28 am |
degruch
Can't find any pics unfortunately, but the GT's had a single speaker on one side of the rear parcel shelf from memory. I wanted 2 of them, so I could hide some new speakers beneath them...they were always black in colour I believe.
| Tue May 13, 2014 10:59 am |
come on you gt owners I have searched the net not too many shots of the rear parcel tray help him out give him a photo ...I thought the early gts had a twin speaker with the pleating same as the rear seats ???
| Tue May 13, 2014 12:27 pm |
heres a pr90 one speaker ..mmmmmmmmmmmmm nice as new reckon the orphanage has seen this car in the flesh (metal)
| Tue May 13, 2014 12:37 pm |
notice the 2 crank handle holes ?? WHY ???
| Tue May 13, 2014 1:03 pm |
degruch
Cheers Davo...got your message to mate, thanks for looking!
| Wed May 14, 2014 8:07 am |
Retroasted
My guess. Would it be that although the bar is common to the sedan, minus the over riders but with the addition of the bump stops, it is mounted higher than the sedan with parking lights below the bar, rather than above as on the sedan? It is then required for a guide for the crank handle? I have seen something similar on another make? Hmmm
| Wed May 14, 2014 8:59 am |
You got it nephew! Some people are observant!  Matt.
| Wed May 14, 2014 12:37 pm |
so lewis does it have a crank handle as the early teardrops have ??? lewis??and farmer have you a photo of your rear parcel deck for duane (gt) cheers davo
| Wed May 14, 2014 9:17 pm |
rod
nice rotary motor in back ground ....looks like 12 a twin dizzy ?
| Wed May 14, 2014 11:27 pm |
hey rod is the rear deck on your the same single speaker ...got a photo cheers davo
| Thu May 15, 2014 5:49 am |
rod
BULLITT wrote: hey rod is the rear deck on your the same single speaker ...got a photo cheers davo yes davo was the same as that one single speaker rear deck I took it out last year ,, made a new rear deck with two speakers ..and new vinal ....still have old rear deck and speaker ...
| Thu May 15, 2014 8:12 am |
rod
heres a pic davo
| Thu May 15, 2014 8:39 am |
