WTD: PR91 GT Parts
degruch
WTD: PR91 GT Parts
Post by degruch »
Hi all, I've requested most of these before, but they're spread amongst various posts - I'm looking for the following PR91 GT parts:
> GT speedo in MPH
> Rear parcel shelf speaker bezel (preferably 2)
> GT radio and bezel
> GT fog lamps and brackets
> GT owners manual
Non-GT specific:
> Rust free rear beaver panel
If anyone has these parts for sale, please let me know.
Duane
Re: WTD: PR91 GT Parts
degruch wrote:Hi all, I've requested most of these before, but they're spread amongst various posts - I'm looking for the following PR91 GT parts:
> GT speedo in MPH
> GT radio and bezel
> GT owners manual
Non-GT specific:
Duane
I have one GT fog lamp with cracked lense. 2 genuine brackets that could be restored although a little bent and chrome is stuffed.
You 'might' be able to cut out the speaker bezels from a couple of sedan parcel trays if all else fails and graft them into a new GT type shelf. ?
Use Vynal spray to complete the job in desired colour.
degruch
Post by degruch »
Thanks Glenn! I may be interested in what you have...just chasing another lead atm.
The speaker bezels are the same on all Bellett models? If so, yes...sedan, GT, any bezels will do, as long as they are black.
degruch wrote:Thanks Glenn! I may be interested in what you have...just chasing another lead atm.
I don't know if they are the same. But does not matter if you are making a whole new board and have 2 sedan ones for example to patch in. Most people won't even notice if they are.
Colour can be changed anyway using spray paint. Especially if common colour, black etc
PR95
Post by PR95 »
Don't know that sedans had a speaker grill, from memory they had a deep well and were slotted where the speaker was attached to a plate under the parcel tray. :?:
PR95 wrote:Don't know that sedans had a speaker grill, from memory they had a deep well and were slotted where the speaker was attached to a plate under the parcel tray. :?:
yes, its moulded into the tray but could be removed with a jig saw very carefully and slotted into a new GT shelf i would think. Would need some careful work but would end up pretty nice i think.
Post by BULLITT »
glenn why don't you help him out and make one for him cheers davo
BULLITT wrote:glenn why don't you help him out and make one for him cheers davo
I don't have 2 sedan shelves !
what i would probably do.......
get two sedan shelves
carefully cut around the grilles with a jig saw, leaving a little extra material to remove them from both shelves. Carefully pare back with sharp knife around the outside to make them 'nice'
insert them into a new blank shelf for the GT. Possibly make shelf from 3mm MDF, covered in vynal, stitched to look like a GT one. Maybe wrap the vynal though the holes. Then glue in vents of course. Ensure the holes cut are very close fit before doing this to make sure the end result looks good.
Paint with Vynal spray
degruch
Post by degruch »
Can't find any pics unfortunately, but the GT's had a single speaker on one side of the rear parcel shelf from memory. I wanted 2 of them, so I could hide some new speakers beneath them...they were always black in colour I believe.
Post by BULLITT »
come on you gt owners I have searched the net not too many shots of the rear parcel tray help him out give him a photo ...I thought the early gts had a twin speaker with the pleating same as the rear seats ???
Post by BULLITT »
heres a pr90 one speaker ..mmmmmmmmmmmmm nice as new reckon the orphanage has seen this car in the flesh (metal)
Post by BULLITT »
notice the 2 crank handle holes ?? WHY ???
degruch
Post by degruch »
Cheers Davo...got your message to mate, thanks for looking! :)
Retroasted
Post by Retroasted »
My guess. Would it be that although the bar is common to the sedan, minus the over riders but with the addition of the bump stops, it is mounted higher than the sedan with parking lights below the bar, rather than above as on the sedan? It is then required for a guide for the crank handle? I have seen something similar on another make? Hmmm
Post by Farmer »
You got it nephew!
Some people are observant!
:) Matt.
Post by BULLITT »
so lewis does it have a crank handle as the early teardrops have ??? lewis??and farmer have you a photo of your rear parcel deck for duane (gt) cheers davo
rod
Post by rod »
nice rotary motor in back ground ....looks like 12 a twin dizzy ?
Post by BULLITT »
hey rod is the rear deck on your the same single speaker ...got a photo cheers davo
rod
Post by rod »
BULLITT wrote:hey rod is the rear deck on your the same single speaker ...got a photo cheers davo
yes davo was the same as that one single speaker rear deck I took it out last year ,, made a new rear deck with two speakers ..and new vinal ....still have old rear deck and speaker ...
rod
Post by rod »
heres a pic davo
