G180 W mls Head Gaskets
flying
Post by flying »
Hi Guys
I am ordering an MLS Head Gasket from Thomas 4 Parts
He can get them made up takes 1 month $265 plus postage
The only other Gasket set kit I could and have got is from MDS Gaskets in Melbourne but this is for the G200 W and the only difference is the Graphite Head Gasket to suit the 87 mm Bore.
Anyone interested in ordering a MLS Gasket ???
Minimum order is 2
Thomas 4 parts website:
http://thomas4parts.com/
Regards
Flying
Re: G180 W mls Head Gaskets
flying wrote:Hi Guys
Minimum order is 2
Regards
Flying
Not sure if i am right here.... i think the Bellett 1800SOHC gasket can be used on the DOHC engine? Chev Luv are often available on ebay if you only need head gasket. This one does not have the section around the cam chain area, but it supplied as a separate gasket i think.
G180_SOHC_head_gasket_ 001.jpg (110.55 KiB) Viewed 19825 times
G180_SOHC_head_gasket_ 002.jpg (103.45 KiB) Viewed 19825 times
flying
Post by flying »
Hi Glenn
That Gasket looks different
Heres a picture of mine compared to a copy of yours -- shold have put some white paper underneath for better contrast
Quick Question -- are the sohc Heads only 8 bolts?
Regards Flying
there seem to be some differences in hole size mainly ? Although, two extra holes also
The LUV seems to have an 'odd' shape (not circle) around the bores, yours does not.
I have another LUV SOHC gasket here also which has the 'extension' for the timing chain area.
Afraid I don't know how many bolt holes are used.
Asroc66
Post by Asroc66 »
They Should be interchangeable
Readily available from USA but very high postage
Asroc66 wrote:They Should be interchangeable
yes they are, the one without the 'extension' has a separate gasket supplied.
Post is expensive sometimes but one one of them i got lucky and paid < $20
flying
Post by flying »
The SOHC Gaskets look close but no banana
flying
Post by flying »
Heres some pictures
Two of the Early Blue Top Twin Cam
and two of a Green Top
Glenns SOHC almost fits the Green Top except for an extra hole required top left but does not fit the blue top which is very similar to the red top G200 W
Green top head is different again with extra water on the Intake side of the head
Regards Flying
Green Top Intake.jpg (160.72 KiB) Viewed 19761 times
Blue Top Intake Resized.jpg (149.36 KiB) Viewed 19761 times
Green Top Resized.jpg (134.23 KiB) Viewed 19761 times
Blue Top Head resized.jpg (140.53 KiB) Viewed 19761 times
Asroc66
Post by Asroc66 »
Hi
Thanks for the heads-up
Another Myth Busted
