Screamin' Squirrel II
Section for your nostalgic Bellett pics, whether the car be yours from long ago or one you've seen racing, parked or broken back in the day!
Teditor
Re: Screamin' Squirrel II
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
...Using A Light Hammer & Chisel To Get The Boot Rubber Out...
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
.Some Rust Repair.
Ted Freeman
Teditor
Post by Teditor »
..Not The Best But I'm Getting There..
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
.....Replacement Of The Boot's Corner Was A Must, Still Not The Best Welds But I Will Keep Going Over Until Correct,So This Corner Still Needs Some Welding To Sort Out The Seam's, (Dad & I Picked Up A 2x4-Foot Sheet Of 1mm Cold-Roll Steel) More Then Enough To Do What We Want.....
Ted Freeman
Teditor
Post by Teditor »
......The Other Corner Has Far More Rust Damage In It......
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
........Grind Her Back A Bit........
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
...........Clean It All Up With A File...........
Ted Freeman
Teditor
Post by Teditor »
............I Carefully Pulled Back The Inner-Skin So To Tap-Out All The Rust Flakes & Crap Which Can Be Seen Through The Rust Holes, All Up There Was About 4 Heaped Table Spoons Worth Of Rust Flakes & Crap That I Was Able To Get Out............
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
