Screamin' Squirrel II
Re: Screamin' Squirrel II
- Attachments
- --Bellett--3.JPG (2.65 MiB) Viewed 50466 times
Ted Freeman
...Using A Light Hammer & Chisel To Get The Boot Rubber Out...
- Attachments
- --Bellett--4.JPG (2.92 MiB) Viewed 50466 times
Ted Freeman
- Attachments
- Bellett--Boot--1--.JPG (2.55 MiB) Viewed 50437 times
Ted Freeman
- Attachments
- Bellett--Boot--2--.JPG (2.88 MiB) Viewed 50436 times
Ted Freeman
- Attachments
- Bellett--Boot--3--.JPG (2.89 MiB) Viewed 50438 times
Ted Freeman
.Some Rust Repair.
- Attachments
- --Bellett-Boot-Rust-Repair--1.JPG (3.1 MiB) Viewed 50379 times
Ted Freeman
..Not The Best But I'm Getting There..
- Attachments
- --Bellett-Boot-Rust-Repair--2.JPG (3.01 MiB) Viewed 50378 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--3.JPG (3.19 MiB) Viewed 50378 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--4.JPG (3.49 MiB) Viewed 50378 times
Ted Freeman
.....Replacement Of The Boot's Corner Was A Must, Still Not The Best Welds But I Will Keep Going Over Until Correct,So This Corner Still Needs Some Welding To Sort Out The Seam's, (Dad & I Picked Up A 2x4-Foot Sheet Of 1mm Cold-Roll Steel) More Then Enough To Do What We Want.....
- Attachments
- --Bellett-Boot-Rust-Repair--5.JPG (2.41 MiB) Viewed 50378 times
Ted Freeman
......The Other Corner Has Far More Rust Damage In It......
- Attachments
- --Bellett-Boot-Rust-Repair--6.JPG (2.98 MiB) Viewed 50378 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--7.JPG (2.56 MiB) Viewed 50375 times
Ted Freeman
........Grind Her Back A Bit........
- Attachments
- --Bellett-Boot-Rust-Repair--8.JPG (2.61 MiB) Viewed 50375 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--9.JPG (2.63 MiB) Viewed 50375 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--10.JPG (2.57 MiB) Viewed 50375 times
Ted Freeman
...........Clean It All Up With A File...........
- Attachments
- --Bellett-Boot-Rust-Repair--11.JPG (2.78 MiB) Viewed 50375 times
Ted Freeman
............I Carefully Pulled Back The Inner-Skin So To Tap-Out All The Rust Flakes & Crap Which Can Be Seen Through The Rust Holes, All Up There Was About 4 Heaped Table Spoons Worth Of Rust Flakes & Crap That I Was Able To Get Out............
- Attachments
- --Bellett-Boot-Rust-Repair--12.JPG (2.58 MiB) Viewed 50375 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--13.JPG (2.52 MiB) Viewed 50375 times
Ted Freeman
