Screamin' Squirrel II
Re: Screamin' Squirrel II
..I Paid Close Attention To The Depth I Was Cutting As I Was Unsure If The Outer/Inner Skin Was Good Or Not..
- Attachments
- -Bellett-Rust-Repair--2.JPG (2.29 MiB) Viewed 56381 times
Ted Freeman
...Once Cut & Pried Apart I Was Able To See Why The Bulge Was There, Plenty Of Rust Within As I Expected...
- Attachments
- -Bellett-Rust-Repair--3.JPG (2.35 MiB) Viewed 56381 times
Ted Freeman
....Quite The Mess....
- Attachments
- -Bellett-Rust-Repair--4.JPG (2.65 MiB) Viewed 56381 times
Ted Freeman
.....After I Cleaned Out All The Rust Shards I Was Then Able To See Just How Bad The Surface Rust Was On The Inner Faces & Made The Choice To Continue Cutting My Way Through To Continue On With My Original Plan Of Replacing Both Sections.....
- Attachments
- -Bellett-Rust-Repair--5.JPG (2.25 MiB) Viewed 56381 times
Ted Freeman
......Rough-Cut......
- Attachments
- -Bellett-Rust-Repair--6.JPG (2.2 MiB) Viewed 56381 times
Ted Freeman
.......File & De-Burr All The Surfaces.......
- Attachments
- -Bellett-Rust-Repair--7.JPG (2.15 MiB) Viewed 56379 times
Ted Freeman
........I Would Of Loved To Do A Skin Off Restoration Given All The Potential Rust Between All But Maybe Later On In Life, At Least She Would Be A Good Base To Do So After This Restoration........
- Attachments
- -Bellett-Rust-Repair--8.JPG (2.48 MiB) Viewed 56380 times
Ted Freeman
.........A Closer Look At The Exposed Sides.........
- Attachments
- -Bellett-Rust-Repair--9.JPG (3.24 MiB) Viewed 56380 times
Ted Freeman
..........& Now A Closer Look At The Unexposed Sides.(Scary)..........
- Attachments
- -Bellett-Rust-Repair--10.JPG (3.25 MiB) Viewed 56380 times
Ted Freeman
.Back At It Again.
- Attachments
- -Bellett-1.JPG (2.11 MiB) Viewed 56343 times
Ted Freeman
..Dad Suggested To Grind The Inner Sheet In A-Bit So To Create A Step All Way Round Which Will Help Absorb The Heat When Welding & It Works To, It Greatly Lessened The Chance Of A Blow-Through When Welding (Thanks Dad)..
- Attachments
- -Bellett-2.JPG (2.11 MiB) Viewed 56344 times
Ted Freeman
...A Few Dummy Fits & Fine Tuning Before Welding, It's Easy To Get Ahead Of Oneself Sorry...
- Attachments
- -Bellett-3.JPG (2.25 MiB) Viewed 56344 times
Ted Freeman
....I Hit It With A Few Spot-Welds So It Won't Distort When Welding It In....
- Attachments
- -Bellett-4.JPG (2.27 MiB) Viewed 56344 times
Ted Freeman
.....& Away I Went!
- Attachments
- -Bellett-5.JPG (2.52 MiB) Viewed 56344 times
Ted Freeman
......Not The Best Job I Know, It's Quite Hard To Weld & Work With Half Rusted Sheet Metal (That Being All The Bellett's Metal) But Dad's Step Idea Helped Dissipate A-Lot Of The Heat & Most Of The Welds Were Fused Correct From What I Can See But I Can Also See A-Lot Of Bad Welds (More So After The Clean Up) & A Need To Go Back Over It Again Haunts My Mind......
- Attachments
- -Bellett-6.JPG (2.8 MiB) Viewed 56342 times
Ted Freeman
.......After The Welds Are Sanded Back Is When I Get To Check & See If Its All Fused In Or Not, (?).......
- Attachments
- -Bellett-7.JPG (2.44 MiB) Viewed 56341 times
Ted Freeman
........From The Other Side........
- Attachments
- -Bellett-8.JPG (2.8 MiB) Viewed 56341 times
Ted Freeman
.........Sizing Up The Next Bit.
I forgot To Say That On The Inside I Should Have Stripped The Paint Back Further As It Got Burnt.........
..In-Put--Techniques--Methods..Knowledge.. All Welcome ..
- Attachments
- -Bellett-9.JPG (2.76 MiB) Viewed 56340 times
Ted Freeman
.The Boots Inner After A Coat Of Etch Primer.
- Attachments
- -Bellett-Boot-1.JPG (3.72 MiB) Viewed 56294 times
Ted Freeman
- Attachments
- -Bellett-Boot-2.JPG (2.35 MiB) Viewed 56294 times
Ted Freeman
