Screamin' Squirrel II
Section for your nostalgic Bellett pics, whether the car be yours from long ago or one you've seen racing, parked or broken back in the day!
Teditor
Re: Screamin' Squirrel II
Post by Teditor »
..I Paid Close Attention To The Depth I Was Cutting As I Was Unsure If The Outer/Inner Skin Was Good Or Not..
Ted Freeman
Teditor
Post by Teditor »
...Once Cut & Pried Apart I Was Able To See Why The Bulge Was There, Plenty Of Rust Within As I Expected...
Ted Freeman
Teditor
Post by Teditor »
....Quite The Mess....
Ted Freeman
Teditor
Post by Teditor »
.....After I Cleaned Out All The Rust Shards I Was Then Able To See Just How Bad The Surface Rust Was On The Inner Faces & Made The Choice To Continue Cutting My Way Through To Continue On With My Original Plan Of Replacing Both Sections.....
Ted Freeman
Teditor
Post by Teditor »
......Rough-Cut......
Ted Freeman
Teditor
Post by Teditor »
.......File & De-Burr All The Surfaces.......
Ted Freeman
Teditor
Post by Teditor »
........I Would Of Loved To Do A Skin Off Restoration Given All The Potential Rust Between All But Maybe Later On In Life, At Least She Would Be A Good Base To Do So After This Restoration........
Ted Freeman
Teditor
Post by Teditor »
.........A Closer Look At The Exposed Sides.........
Ted Freeman
Teditor
Post by Teditor »
..........& Now A Closer Look At The Unexposed Sides.(Scary)..........
Ted Freeman
Teditor
Post by Teditor »
.Back At It Again.
Ted Freeman
Teditor
Post by Teditor »
..Dad Suggested To Grind The Inner Sheet In A-Bit So To Create A Step All Way Round Which Will Help Absorb The Heat When Welding & It Works To, It Greatly Lessened The Chance Of A Blow-Through When Welding (Thanks Dad)..
Ted Freeman
Teditor
Post by Teditor »
...A Few Dummy Fits & Fine Tuning Before Welding, It's Easy To Get Ahead Of Oneself Sorry...
Ted Freeman
Teditor
Post by Teditor »
....I Hit It With A Few Spot-Welds So It Won't Distort When Welding It In....
Ted Freeman
Teditor
Post by Teditor »
.....& Away I Went!
Ted Freeman
Teditor
Post by Teditor »
......Not The Best Job I Know, It's Quite Hard To Weld & Work With Half Rusted Sheet Metal (That Being All The Bellett's Metal) But Dad's Step Idea Helped Dissipate A-Lot Of The Heat & Most Of The Welds Were Fused Correct From What I Can See But I Can Also See A-Lot Of Bad Welds (More So After The Clean Up) & A Need To Go Back Over It Again Haunts My Mind......
Ted Freeman
Teditor
Post by Teditor »
.......After The Welds Are Sanded Back Is When I Get To Check & See If Its All Fused In Or Not, (?).......
Ted Freeman
Teditor
Post by Teditor »
........From The Other Side........
Ted Freeman
Teditor
Post by Teditor »
.........Sizing Up The Next Bit.
I forgot To Say That On The Inside I Should Have Stripped The Paint Back Further As It Got Burnt.........
..In-Put--Techniques--Methods..Knowledge.. All Welcome ..
Ted Freeman
Teditor
Post by Teditor »
.The Boots Inner After A Coat Of Etch Primer.
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
