View unanswered posts | View active topics It is currently Wed Jun 10, 2026 12:40 pm
bellett deluxe versus standard bellett
hi guys i am trying to work out the difference between a standard and a deluxe please shed some light if you can Am i correct in following tinted windows , chrome door surrounds , chrome oiece in between doors , deluxe badge on both front gaurds and on the boot {rhs} some later had the word deluxe on a badge ? full chrome wheel trims , optional white walls, inside had a radio, seatbelts , carpets, and a clock sometimes in the dash and some on the dash.2 speed washers this is the tricky bit did they have different wiring or just added to the existing loom also did they have an electric pump like the gt.s and finally a heater which had a pull out 3 position lever where the existing controls are Is there anything ive missed . i know that dave will know all this imfo regards davo in qld
Sat Jan 09, 2010 5:36 am
Hi Dave,
The trim and brightwork info looks about right as far as I know.
tinted windows
stainless steel door window frames & trim plate on B-pillar
deluxe badging on front quarters (1969-model has small 'deluxe' badge on back different to the shield on the side)
wheelcovers
radio
carpets instead of mats
clock on top of dashboard (early dash)
clock in dashboard next to speedo (1966.5 onwards)
2 speed wipers - I've seen the 2-speed wipers in a non-Deluxe as well
I'm not sure if whitewalls were an actual option, nor can I tell you for certain if they had seatbelts.
Can anybody help Dave in Queensland determine if the wiring was different? I simply don't know.
Mon Jan 11, 2010 2:13 am
Also inside the trim work was different on the seats both front and rear, the front seat rail system is a dual lock system as compaired to single lock on the 67 sedan. The seat mounts are also different as we tried to swap out seats between 67 sedan and deluxe sedan. The wiring for the switch is same as far as i know but you have to also fit the dual-speed wiper motor for the system to work. Also think the water bottle was the standard bag unit with the vacuum pump manual squirter. Only GT got the electric unit. Clock was in all the 68-69 models but the rarer 66-67 deluxe may have not got the clock. my 2 cents worth.
Chris
Mon Jan 11, 2010 2:24 am
A perv at the brochures in the brochure section may help as well.
Mon Jan 11, 2010 3:52 am
Car(s): 66 GTPR90
Re interior deluxe sedan also had GTstyle arm rests on front & sometimes on rear doors
Rear doors seemed optional as to mood of person fitting but definately on front doors
Also 67-68 deluxe had woodgrain dash facia same as GT& hence are inter changable with same eg clock hole in dash facia becomes oil pressure guage
cheers ken
Mon Jan 11, 2010 4:52 am
Oh yeah I forgot about that! Ross's 1969 Deluxe has the arm rests and I remember seeing that on other earlier deluxes.
Plus the woodgrain.... class!
Mon Jan 11, 2010 5:44 am
hi guys thanks for all your replies ..i went into my pandoras box and found a twin switch the loom has 4 pins and 4 wires they look identical one is coded with twin switch OS-A1 W -8 the other single speed OS-D1 W-7 .. 3 wires a bit of useless imfo but someone may need it someday i will hook it up tomorrow regards dave in qld
Mon Jan 11, 2010 6:54 am
another one...
69 deluxe has a small ashtray for the rear passenger mounted to the trans tunnel, just behind the handbrake.
Fri Jan 15, 2010 6:11 am
Don't they all have that ash tray, not just the deluxe's?
Tue Feb 09, 2010 2:27 am
nope, just the deluxe. my 69 deluxe it, as did the other ones i've seen.
all the standards never had it, but the earlier deluxes may have.
GT's definitly never had it either.
Tue Feb 09, 2010 6:44 am
My 68 deluxe had the ashtray in the back. It was first reg in December 1968. It was a bit of a crossdresser as it had 1969 inner guards. and quite a few 69 bits and bobs. I think it was maybe one of the last off the line before changeover. I have seen this on some early Holdens and Fords.
Tue Feb 09, 2010 10:31 am
My 1966.5 has gone the central ashtray.
I thought it must have been standard fitment to all bucket-seated sedans.
Tue Feb 09, 2010 11:56 am
I don't think I've ever seen a car without the rear ashtray - all mine have 'em, incl the '65 parts donors.
'Barn Find' has one in the back of the front bench.
Doris also has 3 passenger grab handles in the roof (standard car door pulls).
But no dashtop clock, eved though the handbook shows one!
Tue Feb 09, 2010 12:43 pm
I guess when your'e using the ashtray, ya' not bothered about what time it is !!
Here's a thought PR91, what about an ashtray mounted on the drive shaft well on GT's, Deluxe style.
Gotta check out that ashtray at all Japan, 2ldohc.....
Tue Feb 09, 2010 12:56 pm
of all the belletts i've had (standard's and deluxe's), the deluxe's were the only ones with it "still" fitted, but as most of these cars were usually wrecks when i got them (for parts), the tray could have been pilfered before i got to them too. i know the race car definitly didnt have the tray or the mount there when i stripped it to rebuild either, and it was a road car when i got it.
i think it'll be too far back towards the rear seat, B, and just be a pain to step over, as the handbrake in a GT is further back along the floor pan than what it is in a sedan. the sedan has a space there that it fits in perfectly, but the handbrake uses this space in the GT. reason is that the gearstick in the GT is further back than in a sedan, meaning they had to move the handbrake back as well.
Tue Feb 09, 2010 1:45 pm
Yeah PR91, I had a quick look last night, and yes, could mount an ashtray but you would certainly end up kicking it around the back seat floor pan !!
had no idea the mounting distances were different in GT's for gearsticks and hand brakes,... interesting
Wed Feb 10, 2010 2:11 pm
I don't require the conventional use for the ashtray, but it has another - It props a 1 litre drink bottle between the seats & holds a Mars bar! mmmmmm, so chooooclaateeeee....aaaarrccggg.....
Gotta go - cuppa time! Matt.
Fri Feb 12, 2010 9:35 pm
What about chocolate and a good coffee?
Fri Feb 12, 2010 10:05 pm
Cuppa tea and good chocolate is my vote, lol.
As people are talking about handbrakes, just wondering if the mechanism under the floor is the same (ie distnace mountings etc) is the same for bench seat and bucket seat.
Havent had a chance to look under a bucket seat car yet, and i want to move my handbrake to the centre.
Sat Feb 13, 2010 12:45 am
Only thing that improves a Mars Bar is a good Coffee, mate! Might have to watch for one of those machines!
Hey Rob, I'll have to check out the difference. (I know G.T. is different) I'd have a spare centre mechanism if you need it.
Thu Feb 18, 2010 12:20 pm
