g200w or g180w dipstick
Waldo
Car(s): 1968 Bellett GT
Post by Waldo »
hey guys im after a g200w or g180w dipstick if anyone has one spare. thanks
Re: g200w or g180w dipstick
Post by PR91 »
Depends on what sump and dip stick tube you have.... there were 2 or 3 different ones.
Waldo
Post by Waldo »
I have this type sump. Or does anyone know what other dipstick would fit this sump? One i could cut down to suit that will just fit the tube
flying
Post by flying »
Waldo
That sumps looks similar to mine
I will have a look tomorrow night
i do not have a spare but i will take a photo, measure it etc
Cheers Flying
Post by PR91 »
Try a Gemini stick. I think the rubber sleeve is the same size and the length should be close. A tape measure will confirm or deny.
But make sure it's the same style Gemini sump.... because they had a couple of different ones as well.
flying
Post by flying »
Waldo
The Dipstick is 300 mm long from the tip of the stick to the inside base. The high and low marks are 15 mm and 40 mm from the tip.
The blade looks about 5 mm wide and the stopper is about 8mm in diameter.
Hope this Helps
Flying
PR91 wrote:Try a Gemini stick. I think the rubber sleeve is the same size and the length should be close. A tape measure will confirm or deny.
I think so too Brett. When I put a DOHC in one of my cars I used part (3/4) of a Gemini sump.
