What is missing from this engine bay? (only temporarily
Engine Bay
1968GT
Engine Bay
OK Gents, so you know Bellett engine bays
flying
- Car(s): 1967 GT Bellett
Re: Engine Bay
The Upright hook that sits just behind the thermostat housing that you connect the chain to when lifting out the engine
Flying
Flying
KJB
Re: Engine Bay
The black paint off the coil...........
Re: Engine Bay
the grille holding the windscreen washers ..came out of my bellett not your gt (different colour) ??????cheers davo any more clues??
Re: Engine Bay
water washers not hooked up between bottle and the 2 speed pump ?? davo
Re: Engine Bay
Davo would be right
I will say the pipe from the air cleaners to catch can
oz_toffa
Re: Engine Bay
the correct original engine dark red colour???
1968GT
Re: Engine Bay
I will put you out your misery Guys.
Flying was correct,
I had the front engine lifting hook off to paint, it was looking a bit crappy so I thought I would make it look a bit better.
Since it has been so quiet on bellett.net, I thought I would stir something up again.
Bullitt thought the grille is blue like his sedan, hence Dave's comment ABOUT BEING MISSING FROM HIS CAR,
however because it was such a beautiful day here in Mudgee, the grille is chrome and this may sound ridiculous, BUT the blue reflection in the chrome grille, would you believe was the blue sky!!! NO JOKE!!!
Flying was correct,
oz_toffa
Re: Engine Bay
sure hope you didn't get sunburnt....
remember
Slip, Slop, Slap and a hat
remember
oz_toffa
Re: Engine Bay
remember
remember
Early GT
Re: Engine Bay
Hey Dave, how good does your engine bay look in the sun!
almost better than mine
Ken is right. The Coil should be black with a little hitachi brand on it. Good point Greg... I think all later model crankcase ventilators had the outlet with a hose to the carbs.
Also, There isn't any small C shaped bracket on the nut between No 1 and 2 spark plugs support the thermostat wire
cheers, Lewis
cheers, Lewis
Re: Engine Bay
If you want to get real picky it needs 2 more camshafts
Yes i did say two more cause the dohc engine has 3 cams.
oz_toffa
Re: Engine Bay
do you mean the balance shaft in the lower part of the engine???
sounding more like a Mitsubishi every day
Re: Engine Bay
they are the same block as a 180s the 3rd cam runs the oil pump and if you take the welch plug out you could run a dizzy.
Re: Engine Bay
This GT never had any pipes for breather to the carbs.Early GT wrote:Hey Dave, how good does your engine bay look in the sun!almost better than mine
Also, There isn't any small C shaped bracket on the nut between No 1 and 2 spark plugs support the thermostat wire![]()
cheers, Lewis
1968GT
Re: Engine Bay
THANK YOU GLENN!
That is exactly what I was going to say, from what you told me, the engine bay is original! Also shown in the Wheels road test of the same model!
I did not say "what is the wrong colour", I did say what is missing.
Re: Engine Bay
yes, all original, bar a bit of a clean up1968GT wrote:THANK YOU GLENN!![]()
PR95
Re: Engine Bay
Where does the top hose off the blue can go to then?
Re: Engine Bay
gee, it's a while ago, but into the sump.PR95 wrote:Where does the top hose off the blue can go to then?
PR95
Re: Engine Bay
Top one should go to carbies, one below it to Block, just below the head, and one under catch can to tube in the sump.
