View unanswered posts | View active topics It is currently Sat Jun 13, 2026 1:05 pm
Engine Bay
OK Gents, so you know Bellett engine bays ;)
What is missing from this engine bay? (only temporarily :lol: :roll: )
Mon Mar 25, 2013 5:07 am
The Upright hook that sits just behind the thermostat housing that you connect the chain to when lifting out the engine
Flying
Mon Mar 25, 2013 5:16 am
The black paint off the coil...........
Mon Mar 25, 2013 5:27 am
the grille holding the windscreen washers ..came out of my bellett not your gt (different colour) ??????cheers davo any more clues??
Mon Mar 25, 2013 6:29 am
water washers not hooked up between bottle and the 2 speed pump ?? davo
Mon Mar 25, 2013 7:05 am
Davo would be right :!: I will say the pipe from the air cleaners to catch can :?:
Mon Mar 25, 2013 8:24 am
the correct original engine dark red colour???
Mon Mar 25, 2013 9:22 am
I will put you out your misery Guys. ;)
Flying was correct, :o I had the front engine lifting hook off to paint, it was looking a bit crappy so I thought I would make it look a bit better.
Since it has been so quiet on bellett.net, I thought I would stir something up again. 8-)
Bullitt thought the grille is blue like his sedan, hence Dave's comment ABOUT BEING MISSING FROM HIS CAR, :lol: however because it was such a beautiful day here in Mudgee, the grille is chrome and this may sound ridiculous, BUT the blue reflection in the chrome grille, would you believe was the blue sky!!! NO JOKE!!! :lol:
Mon Mar 25, 2013 9:56 am
sure hope you didn't get sunburnt....
remember
Slip, Slop, Slap and a hat
Mon Mar 25, 2013 10:04 am
remember
Mon Mar 25, 2013 10:29 am
Hey Dave, how good does your engine bay look in the sun! 8-) almost better than mine ;)
Ken is right. The Coil should be black with a little hitachi brand on it. Good point Greg... I think all later model crankcase ventilators had the outlet with a hose to the carbs.
Also, There isn't any small C shaped bracket on the nut between No 1 and 2 spark plugs support the thermostat wire :)
cheers, Lewis
Mon Mar 25, 2013 10:52 am
If you want to get real picky it needs 2 more camshafts 8-) Yes i did say two more cause the dohc engine has 3 cams.
Mon Mar 25, 2013 11:16 am
do you mean the balance shaft in the lower part of the engine???
sounding more like a Mitsubishi every day
Mon Mar 25, 2013 11:22 am
they are the same block as a 180s the 3rd cam runs the oil pump and if you take the welch plug out you could run a dizzy.
Mon Mar 25, 2013 8:17 pm
cheers, Lewis
This GT never had any pipes for breather to the carbs.
Mon Mar 25, 2013 9:43 pm
THANK YOU GLENN! 8-)
That is exactly what I was going to say, from what you told me, the engine bay is original! Also shown in the Wheels road test of the same model!
I did not say "what is the wrong colour", I did say what is missing. :lol:
Mon Mar 25, 2013 11:32 pm
yes, all original, bar a bit of a clean up :)
Tue Mar 26, 2013 12:23 am
Where does the top hose off the blue can go to then?
Tue Mar 26, 2013 1:48 am
gee, it's a while ago, but into the sump.
Tue Mar 26, 2013 1:52 am
Top one should go to carbies, one below it to Block, just below the head, and one under catch can to tube in the sump.
Tue Mar 26, 2013 2:02 am
Users browsing this forum: Baidu [Spider] and 37 guests
