TIE ROD ENDS
- Glenn
- Contact:
TIE ROD ENDS
I was in the wreckers the other day and saw a couple of tie rod ends.......... CAUTION, i have no idea if these actually fit but they look similar in size to Bellett. Info given as is... ! Might be worth checking further if one has a spare steering arm ( I don't) to try the fit, and if ok, measure up length, thread size etc.
- Attachments
- TIEROD_ISUZU__20140808_133620.jpg (295.78 KiB) Viewed 97100 times
- TIEROD_ISUZU__20140808_133634.jpg (285.96 KiB) Viewed 97100 times
- TIEROD_ISUZU__20140808_133636.jpg (283.45 KiB) Viewed 97099 times
- Glenn
- Contact:
Re: TIE ROD ENDS
Kia...... forgot to check actual model.
- Attachments
- TIEROD-KIA_2002_20140808_133849.jpg (249.57 KiB) Viewed 97098 times
- TIEROD_KIA_20140808_133817.jpg (236.87 KiB) Viewed 97098 times
67GT
Re: TIE ROD ENDS
Guys,
Did anyone get to check these out ?
Or does anyone know of any other tie rod ends out there that we can use on a Bellett ?
- Asroc66
Re: TIE ROD ENDS
Hi all
I am still on the hunt for Tie rod ends
Has anyone ever tried Datsun 200B or Toyota Corona ?
- Stickman
- Contact:
Re: TIE ROD ENDS
Not me
I need some but haven't bothered to look into anything yet........
I'm a lazy lazy man
I'm a lazy lazy man
- Glenn
- Contact:
Re: TIE ROD ENDS
The critical part is the taper. The thread section can be overcome with an adapter if needed.Asroc66 wrote:Anyone?
- Asroc66
Re: TIE ROD ENDS
Negative for the Corona, taper too big
Next..... Datsun 200B / 240K
Re: TIE ROD ENDS
this is the ones ...in japan ...on yahoo
- Attachments
- img_1_m[1].jpg (152.1 KiB) Viewed 96371 times
- Asroc66
Re: TIE ROD ENDS
Yep
They Could be the ones....
I'm trying to find a longer solution for all by finding cheap readily available alternative.....
Much like the brake upgrade....
Thinking long term so we can keep enjoying our little cars
- Attachments
- image.jpg (1.94 MiB) Viewed 96364 times
Re: TIE ROD ENDS
this way up easier to compare
- Attachments
- img_1_m[1].jpg (152.1 KiB) Viewed 96356 times
Re: TIE ROD ENDS
sorry cant turn the pic ,,,
Re: TIE ROD ENDS
Brake upgrade is already done.
Why reinvent the wheel?
- Asroc66
Re: TIE ROD ENDS
Finally found the add in Japan
$388 + Postage is the starting bit.......
So my point wasn't specifically relating to the brake upgrade as such rather to find a cheap, readily available alternative to the NOS Bellett tie rod ends for standard vehicles....
CQGT
Re: TIE ROD ENDS
The part number 44350-370 is the genuine number for sedans and GT's up to '66.5.
After that date it is 44350-418. According to Isuzu there is NO interchange.
They changed the steering arm at the same time. If I had a used arm and end off of a
vehicle I would use both to be safe. But. Before I do. I would check the history of the donor
and also check dimensions.
Isuzu did quite a lot of changes in the front end around certain chassis numbers and dates. '66/'67.
I haven't got any parts for the steering and suspension for vehicles prior to "66.5 so I'm not able to
compare. Maybe somebody with access to these parts might be able to check.
- Asroc66
Re: TIE ROD ENDS
Alright boys and girls
Hard work is done
Place your orders
Mike Quinn Precision Engineering
Unit 32/788-798 Marion Rd
Marion
SA 5043
08 8298 7066
Hard work is done
Place your orders
Marion
SA 5043
08 8298 7066
- Attachments
- image.jpg (288.72 KiB) Viewed 96246 times
- Stickman
- Contact:
Re: TIE ROD ENDS
Who's the man?? You the man!!
67GT
Re: TIE ROD ENDS
Well done. You are worth your weight in gold.
Is a bulk order going in, or every one for themselves?
- Asroc66
Re: TIE ROD ENDS
Mike is a top bloke
He does ask that someone fit and test drive to be 100% sure no hang-ups
We are pretty damn sure all will be good though for early models as I supplied 66-67 rod ends as in picture as well as steering arms off the spindles
Bulk order would be welcomed though
That's up to you guys from here
