TIE ROD ENDS
Any interesting tech facts involving parts interchangeability? Post them here!
TIE ROD ENDS
I was in the wreckers the other day and saw a couple of tie rod ends.......... CAUTION, i have no idea if these actually fit but they look similar in size to Bellett. Info given as is... ! Might be worth checking further if one has a spare steering arm ( I don't) to try the fit, and if ok, measure up length, thread size etc.
Re: TIE ROD ENDS
Kia...... forgot to check actual model.
67GT
Re: TIE ROD ENDS
Post by 67GT »
Guys,
Did anyone get to check these out ?
Or does anyone know of any other tie rod ends out there that we can use on a Bellett ?
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Hi all
I am still on the hunt for Tie rod ends
Has anyone ever tried Datsun 200B or Toyota Corona ?
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Anyone?
Re: TIE ROD ENDS
Post by Stickman »
Not me
I need some but haven't bothered to look into anything yet........
I'm a lazy lazy man :roll:
Re: TIE ROD ENDS
Asroc66 wrote:Anyone?
The critical part is the taper. The thread section can be overcome with an adapter if needed.
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Negative for the Corona, taper too big
Next..... Datsun 200B / 240K
Re: TIE ROD ENDS
Post by BULLITT »
this is the ones ...in japan ...on yahoo
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Yep
They Could be the ones....
I'm trying to find a longer solution for all by finding cheap readily available alternative.....
Much like the brake upgrade....
Thinking long term so we can keep enjoying our little cars
Re: TIE ROD ENDS
Post by BULLITT »
this way up easier to compare
Re: TIE ROD ENDS
Post by BULLITT »
sorry cant turn the pic ,,,
Re: TIE ROD ENDS
Post by PR91 »
Brake upgrade is already done.
Why reinvent the wheel?
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Finally found the add in Japan
$388 + Postage is the starting bit.......
So my point wasn't specifically relating to the brake upgrade as such rather to find a cheap, readily available alternative to the NOS Bellett tie rod ends for standard vehicles....
CQGT
Re: TIE ROD ENDS
Post by CQGT »
The part number 44350-370 is the genuine number for sedans and GT's up to '66.5.
After that date it is 44350-418. According to Isuzu there is NO interchange.
They changed the steering arm at the same time. If I had a used arm and end off of a
vehicle I would use both to be safe. But. Before I do. I would check the history of the donor
and also check dimensions.
Isuzu did quite a lot of changes in the front end around certain chassis numbers and dates. '66/'67.
I haven't got any parts for the steering and suspension for vehicles prior to "66.5 so I'm not able to
compare. Maybe somebody with access to these parts might be able to check.
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Alright boys and girls
Hard work is done
Place your orders
Mike Quinn Precision Engineering
Unit 32/788-798 Marion Rd
Marion
SA 5043
08 8298 7066
Re: TIE ROD ENDS
Post by Stickman »
:P
Who's the man?? You the man!!
67GT
Re: TIE ROD ENDS
Post by 67GT »
Well done. You are worth your weight in gold.
Is a bulk order going in, or every one for themselves?
Asroc66
Re: TIE ROD ENDS
Post by Asroc66 »
Mike is a top bloke
He does ask that someone fit and test drive to be 100% sure no hang-ups
We are pretty damn sure all will be good though for early models as I supplied 66-67 rod ends as in picture as well as steering arms off the spindles
Bulk order would be welcomed though
That's up to you guys from here
Gunna
Re: TIE ROD ENDS
Post by Gunna »
THANK
YOU
:D
