Screamin' Squirrel II
Re: Screamin' Squirrel II
..After One Good Coat Of Stripper..
- Attachments
- Bellett-Boot-Resto-2-.JPG (3.28 MiB) Viewed 47306 times
Ted Freeman
- Attachments
- Bellett-Boot-Resto-3-.JPG (2.65 MiB) Viewed 47306 times
Ted Freeman
- Attachments
- Bellett-Boot-Resto-4-.JPG (3.04 MiB) Viewed 47306 times
Ted Freeman
- Attachments
- Bellett-Boot-Resto-5-.JPG (3.06 MiB) Viewed 47306 times
Ted Freeman
- Attachments
- Bellett-Boot-Resto-6-.JPG (2.85 MiB) Viewed 47306 times
Ted Freeman
- Attachments
- Bellett-Boot-Resto-7-.JPG (3.12 MiB) Viewed 47306 times
Ted Freeman
........After The Paint Stripper I Will Go Over All Of The Insides With Various Types Of Abrasives To Achieve The Bare Metal Result I Desire, Then & Only Then Will I Start Etch Priming & So Forth........
- Attachments
- Bellett-Boot-Resto-8-.JPG (2.6 MiB) Viewed 47306 times
Ted Freeman
.........After The Paint Stripping Most Of The Final Bare Metalin' Will Be With The Air Dremmal, I Have A Small Wire Brush Wheel Displayed Here, Others Such As What I Call (Carpet Disc's) Will Give A Far Better Result, Initially I Used The Wire Brush Wheel To Get The Inner Left Door To Bare-Metal Without Using Paint Stripper, So Methods Are Constantly Evolving.........
- Attachments
- Bellett-Boot-Resto-9-.JPG (2.68 MiB) Viewed 47305 times
Ted Freeman
..........The Two Front Guards Needing A Fair Bit Of Work To Get Them Both Up-To Par..........
- Attachments
- Bellett-Left-&-Right-Front-Guards-.JPG (2.77 MiB) Viewed 47304 times
Ted Freeman
...........Tucked Away So The Next Item Can Be Started & Prepped...........
- Attachments
- Bellett-Left-Door-&-Pillar-All-Wrapped-Up-.JPG (2.84 MiB) Viewed 47304 times
Ted Freeman
............Dad Is Prepping For Fuel Tank Removal............
- Attachments
- Dad-Working-On-Fuel-Tank-.JPG (3.24 MiB) Viewed 47304 times
Ted Freeman
.The Various Ways Of Achieving The Desired Bare-Metal Results, I Now Opt For Paint-Stripper First Then The Rapid Strip Wheel & The Carpet Strip Discs For The Tight Spots, These Three Methods As I Have Found From Personal Experience Will Get The Results Desired & Then Some But Not Saying That This Is The Only Way, But A Way That Works For This Particular Application,
In The Picture Provided One Can See The Different Effects From The Various Products..
- Attachments
- Bare-Metalin'-Product'Z-1-.JPG (1.52 MiB) Viewed 47284 times
Ted Freeman
.Inner Boot Preparation.
- Attachments
- --Bellett-Boot-Inner--1-.JPG (2.65 MiB) Viewed 47278 times
Ted Freeman
- Attachments
- --Bellett-Boot-Inner--2-.JPG (2.75 MiB) Viewed 47278 times
Ted Freeman
- Attachments
- --Bellett-Boot-Inner--3-.JPG (2.62 MiB) Viewed 47278 times
Ted Freeman
- Attachments
- --Bellett-Boot-Inner--4-.JPG (2.61 MiB) Viewed 47278 times
Ted Freeman
- Attachments
- --Bellett-Boot-Inner--5-.JPG (2.81 MiB) Viewed 47277 times
Ted Freeman
Michael is a bit concerned he might be swamping the site with photos, let us know if you tire of our musings!
Ted Freeman
keep em coming mate its good to see postings goes bit slow here at times ...cheers davo
