Screamin' Squirrel II
Section for your nostalgic Bellett pics, whether the car be yours from long ago or one you've seen racing, parked or broken back in the day!
Teditor
Re: Screamin' Squirrel II
Post by Teditor »
..After One Good Coat Of Stripper..
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
........After The Paint Stripper I Will Go Over All Of The Insides With Various Types Of Abrasives To Achieve The Bare Metal Result I Desire, Then & Only Then Will I Start Etch Priming & So Forth........
Ted Freeman
Teditor
Post by Teditor »
.........After The Paint Stripping Most Of The Final Bare Metalin' Will Be With The Air Dremmal, I Have A Small Wire Brush Wheel Displayed Here, Others Such As What I Call (Carpet Disc's) Will Give A Far Better Result, Initially I Used The Wire Brush Wheel To Get The Inner Left Door To Bare-Metal Without Using Paint Stripper, So Methods Are Constantly Evolving.........
Ted Freeman
Teditor
Post by Teditor »
..........The Two Front Guards Needing A Fair Bit Of Work To Get Them Both Up-To Par..........
Ted Freeman
Teditor
Post by Teditor »
...........Tucked Away So The Next Item Can Be Started & Prepped...........
Ted Freeman
Teditor
Post by Teditor »
............Dad Is Prepping For Fuel Tank Removal............
Ted Freeman
very thorough work. Thanks for great pictures
Teditor
Post by Teditor »
.The Various Ways Of Achieving The Desired Bare-Metal Results, I Now Opt For Paint-Stripper First Then The Rapid Strip Wheel & The Carpet Strip Discs For The Tight Spots, These Three Methods As I Have Found From Personal Experience Will Get The Results Desired & Then Some But Not Saying That This Is The Only Way, But A Way That Works For This Particular Application,
In The Picture Provided One Can See The Different Effects From The Various Products..
Ted Freeman
Teditor
Post by Teditor »
.Inner Boot Preparation.
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Ted Freeman
Teditor
Post by Teditor »
Michael is a bit concerned he might be swamping the site with photos, let us know if you tire of our musings!
Ted Freeman
Post by BULLITT »
keep em coming mate its good to see postings goes bit slow here at times ...cheers davo
